Tyristorovy kontroler
Gama
22. 11. 2017, 3:42
TYCO 1Ph - 15
Pouzivany velmy malo, nyni jiz nevyuziju.
Technical data
Load voltage: 1x 400V AC +/-15% (optional other voltages)
Power supply: 1x 230V (external)
Max. rated current: 15-50A
Rotary field: self-synchronizing
Load types: resistive and inductive load
Protection functions: overtemperature shutdown with display of
LED:“Fault“
LED-Display: Run (operation), Start, 100% Uload,
malfunction (fault)
Output: fault message: terminals 6, 7, load: 2A,
230V AC, AC1
Power connections: L1 and L2 input voltage
T1 and T2 output voltage
Control type: phase control (optional: oscillation package)
Power loss: 1,1W per Ampere
Air humidity: 5% bis 95% r.H., non condensing
Protection type: IP20 (IEC 529)
Ambient temperature: operation: 0...+45°C storage: -10°C up to +70°C
Environment: dry, not conductive environment
Mounting: on DIN-Rail system (alternative mounting
possibility with mounting plate)
Enclosure: closed aluminum housing, anodized
Weight: 1,1 kg
Inputs: 0...10V, 0...20mA or potentiometer
(2,5...47kOhm), switchable input-
impedance: 500 Ohm, 50kOhm
Dimensions WxHxD: 92 x 128 x 105 mm
Cena 2000,-Kč + případné poštovné.
