Nejde LinCNC
- Radek-B
Toto je dulezite ve vypisu:
[ 57.434695] config string '0x0378'
[ 65.693588] RTAI[math]: unloaded.
Nemuzes na pocitaci kde paralelni port neni , poustet jeste ke vsemu realtimove parport.
To nejde, nekdo ti to tu uz drive psal, tak te hodne omlouva ze tomu nerozumis.
Taky bych radil abys to na tom notasu provozoval jako simulaci. Pro testy a hrani nepotrebujes vubec
realtime a tomu notasu to velmi ulehci.
cd / zadej svoji cestu /emc2-dev/src/
./autogen.sh
./configure --enable-simulator
make clean
make
RADEK
./autogen.sh
make clean
make
RADEK
automatizace/konstrukce
OK a Sorry jsem už stoho pakoRadek-B píše:Tak automaticky druha vec je ze reknes ze to opet nejde a dej sem vypis.
Print file information:
RUN_IN_PLACE=no
LINUXCNC_DIR=
LINUXCNC_BIN_DIR=/usr/bin
LINUXCNC_TCL_DIR=/usr/lib/tcltk/linuxcnc
LINUXCNC_SCRIPT_DIR=
LINUXCNC_RTLIB_DIR=/usr/realtime-2.6.32-122-rtai/modules/linuxcnc
LINUXCNC_CONFIG_DIR=
LINUXCNC_LANG_DIR=/usr/share/linuxcnc/tcl/msgs
INIVAR=inivar
HALCMD=halcmd
LINUXCNC_EMCSH=/usr/bin/wish8.5
LINUXCNC - 2.5.3
Machine configuration directory is '/home/sly/linuxcnc/configs/Sherline3Axis'
Machine configuration file is 'Sherline3Axis_mm.ini'
INIFILE=/home/sly/linuxcnc/configs/Sherline3Axis/Sherline3Axis_mm.ini
PARAMETER_FILE=stepper.var
TASK=milltask
HALUI=
DISPLAY=axis
Starting LinuxCNC...
Starting LinuxCNC server program: linuxcncsvr
Loading Real Time OS, RTAPI, and HAL_LIB modules
Starting LinuxCNC IO program: io
Starting TASK program: milltask
Starting DISPLAY program: axis
USRMOT: ERROR: command timeout
waiting for s.axes
waiting for s.axes
waiting for s.axes
waiting for s.axes
waiting for s.axes
waiting for s.axes
waiting for s.axes
waiting for s.axes
waiting for s.axes
Shutting down and cleaning up LinuxCNC...
Killing task linuxcncsvr, PID=3526
Killing task milltask, PID=3572
Timeout, trying kill -9
Removing HAL_LIB, RTAPI, and Real Time OS modules
Removing NML shared memory segments
Cleanup done
Debug file information:
Can not find -sec MOT -var MOT -num 1
Can not find -sec IO -var IO -num 1
Can not find -sec LINUXCNC -var NML_FILE -num 1
Can not find -sec EMC -var NML_FILE -num 1
A configuration error is preventing LinuxCNC from starting.
More information may be available when running from a terminal.
3526
PID TTY STAT TIME COMMAND
3572
3572 ? S 0:00 milltask -ini /home/sly/linuxcnc/configs/Sherline3Axis/Sherline3Axis_mm.ini
3572 ? R 0:00 milltask -ini /home/sly/linuxcnc/configs/Sherline3Axis/Sherline3Axis_mm.ini
/usr/bin/linuxcnc: řádek 386: 3572 Zabit (SIGKILL) $EMCTASK -ini "$INIFILE"
Stopping realtime threads
Unloading hal components
Kernel message information:
[ 4221.819414] I-pipe: Domain RTAI registered.
[ 4221.819423] RTAI[hal]: <3.8.1> mounted over IPIPE-NOTHREADS 2.6-03.
[ 4221.819425] RTAI[hal]: compiled with gcc version 4.4.3 (Ubuntu 4.4.3-4ubuntu5) .
[ 4221.819475] RTAI[hal]: mounted (IPIPE-NOTHREADS, IMMEDIATE (INTERNAL IRQs DISPATCHED), ISOL_CPUS_MASK: 0).
[ 4221.819478] PIPELINE layers:
[ 4221.819481] faf75e20 9ac15d93 RTAI 200
[ 4221.819483] c085cb20 0 Linux 100
[ 4221.842357] RTAI[malloc]: global heap size = 2097152 bytes, <BSD>.
[ 4221.842788] RTAI[sched]: IMMEDIATE, MP, USER/KERNEL SPACE: <with RTAI OWN KTASKs>, kstacks pool size = 524288 bytes.
[ 4221.842795] RTAI[sched]: hard timer type/freq = APIC/12468680(Hz); default timing: periodic; linear timed lists.
[ 4221.842799] RTAI[sched]: Linux timer freq = 250 (Hz), TimeBase freq = 1994994000 hz.
[ 4221.842802] RTAI[sched]: timer setup = 999 ns, resched latency = 2944 ns.
[ 4221.842889] RTAI[usi]: enabled.
[ 4221.889098] RTAI[math]: loaded.
[ 4230.373190] RTAI[math]: unloaded.
[ 4230.408372] SCHED releases registered named ALIEN RTGLBH
[ 4230.440346] RTAI[malloc]: unloaded.
[ 4230.536933] RTAI[sched]: unloaded (forced hard/soft/hard transitions: traps 0, syscalls 0).
[ 4230.539854] I-pipe: Domain RTAI unregistered.
[ 4230.539944] RTAI[hal]: unmounted.
Chtěl bych tady poděkovat Radkovi-B, který mi na dálku pomohl nastavit nefunkční LCNC.
Jak a co provedl tak to teda fakt nevím, ale jde to. Nakonec jsem sice rozjel LCNC i pod win přes WMWARE Player a bych při testování nemusel boot.. do lin a zpět na win, ale i tak moc díky, bo jsem stihl okouknout nějaké postupy kompilace.
Perun
Perun
To, že tam není konektor, neznamená, že to nemá parport. Zrovna teď mám na klíně staršího Thinkpada, který má parport konektor jen na docku (a je to opravdu HW parport).slezak77 píše:OK tak jak tedy spustím simulaci, nechápu, že to jednou spustit jde a pak ne, nehledě na to, že na druhém notesu kde parport taky není, to běží, akorát má malé rozlišení tak na něm nedělám a nechal jsem jej ženě na meily.
SABLE-2015
