rád bych se dotázal zda už někdo vyzkoušel tento driver pro malé KM ?
původní popis....
HP200 is a small stepper motor drive module, driving two-phase six-wire stepper motor.
The module through TTL232 way communicate with the host computer, the module has automatic acceleration and deceleration automatic procedures can ensure that the stepper motor drive without losing step process.
Application:
Stepper motor control;
Program control car driver
Specification:
1 length range: ± 800000 stepper motor pulse number once walking
2 Turn the speed range: 20 to 10,000 pulses / sec stepper motor rotation speed
3 Acceleration Level: 1 to 9, with 9 series stepper motor acceleration segment selector
4 drive voltage: 7 ~ 25 V DC
5 Drive Current: <1200 mA , single-phase drive motor is 1.2A
6 Operating Temperature: -40 °C ~ 65 °C
7 Storage Temperature: -40 °C ~ 65 °C
8 Size: 40mm * 35mm * 15 mm
Protocol: (data in HEX code)
1, the serial port communication Format: 9600 baud, no parity, 8 data bits, 1 stop
2 Note: Data for the Binary complement
http://www.ebay.com/itm/HP200-TTL232-St ... 43be5d7053
driver krokového motoru s RS232
Je k tomu i nějakej manuál? Především popis komunikačního protokolu?
Nevim, co od toho ocekavas. Ale treba tady http://www.ebay.com/itm/131057008442" onclick="window.open(this.href);return false; mas za hodne podobne penize 5x driver bipolarniho motoru, arduino a desku jak to spojit.
Do desky by stacilo nahrat nejaky firmware pro reprap a pouzivat jen podmnozinu pro ovladani os (nebo nakonfigurovat grbl).
