PCI karta inštalacia
Páni tak som sa nechal podla rád osadenstva nasmerovať na Linux, dodnes prechádzka ružovým sadom všetko funguje nad moje očakávania bohužial však vidím Linux prvý krát štruktúra mi nieje celkom jasná a dnes sa celý den snažím bezvýsledne nainštalovať pci kartu mcs9865IV-AA, pomali mi dochádzajú nápady čo mám zle, preto by som chcel poprosiť o radu.
Pri kompilacii alebo ako sa tomu hovorí dostanem túto hlášku:
uhy@uhy-desktop:~/Plocha/MCS9865_Linux$ make
rm -f *.mod.c *.o *.ko .*.cmd *.symvers
make -C /lib/modules/2.6.32-122-rtai/build/ SUBDIRS=/home/uhy/Plocha/MCS9865_Linux modules
make[1]: Entering directory `/usr/src/linux-headers-2.6.32-122-rtai'
CC [M] /home/uhy/Plocha/MCS9865_Linux/mcs9865.o
/home/uhy/Plocha/MCS9865_Linux/mcs9865.c: In function ‘serial9865_start_tx’:
/home/uhy/Plocha/MCS9865_Linux/mcs9865.c:498: error: ‘struct uart_port’ has no member named ‘info’
/home/uhy/Plocha/MCS9865_Linux/mcs9865.c: In function ‘check_modem_status’:
/home/uhy/Plocha/MCS9865_Linux/mcs9865.c:611: error: ‘struct uart_port’ has no member named ‘info’
/home/uhy/Plocha/MCS9865_Linux/mcs9865.c: In function ‘receive_chars’:
/home/uhy/Plocha/MCS9865_Linux/mcs9865.c:622: error: ‘struct uart_port’ has no member named ‘info’
/home/uhy/Plocha/MCS9865_Linux/mcs9865.c: In function ‘transmit_chars’:
/home/uhy/Plocha/MCS9865_Linux/mcs9865.c:708: error: ‘struct uart_port’ has no member named ‘info’
/home/uhy/Plocha/MCS9865_Linux/mcs9865.c: In function ‘transmit_chars_dma_stop_done’:
/home/uhy/Plocha/MCS9865_Linux/mcs9865.c:753: error: ‘struct uart_port’ has no member named ‘info’
/home/uhy/Plocha/MCS9865_Linux/mcs9865.c: In function ‘transmit_chars_dma_done’:
/home/uhy/Plocha/MCS9865_Linux/mcs9865.c:769: error: ‘struct uart_port’ has no member named ‘info’
/home/uhy/Plocha/MCS9865_Linux/mcs9865.c: In function ‘receive_chars_dma_done’:
/home/uhy/Plocha/MCS9865_Linux/mcs9865.c:852: error: ‘struct uart_port’ has no member named ‘info’
/home/uhy/Plocha/MCS9865_Linux/mcs9865.c: In function ‘serial9865_handle_port’:
/home/uhy/Plocha/MCS9865_Linux/mcs9865.c:957: error: ‘struct uart_port’ has no member named ‘info’
/home/uhy/Plocha/MCS9865_Linux/mcs9865.c: In function ‘serial9865_probe’:
/home/uhy/Plocha/MCS9865_Linux/mcs9865.c:2068: error: ‘SA_SHIRQ’ undeclared (first use in this function)
/home/uhy/Plocha/MCS9865_Linux/mcs9865.c:2068: error: (Each undeclared identifier is reported only once
/home/uhy/Plocha/MCS9865_Linux/mcs9865.c:2068: error: for each function it appears in.)
make[2]: *** [/home/uhy/Plocha/MCS9865_Linux/mcs9865.o] Chyba 1
make[1]: *** [_module_/home/uhy/Plocha/MCS9865_Linux] Chyba 2
make[1]: Leaving directory `/usr/src/linux-headers-2.6.32-122-rtai'
make: *** [default] Chyba 2
je opravdu potreba to kompilovat? System tu kartu nepozna sam od sebe? Vetsina PCI LPT karet (obe dve ktere sem mel v ruce) se chytily bez nutnosti neco stahovat instalovat nedejboze kompilovat.
Co ti hlasi dmesg popripade lspci?
Martin
Martin
tak zrejme máš pravdu niečo tam je, ako z toho zistím na akú adresu nastaviť EMC?
00:00.0 Host bridge: Intel Corporation 82865G/PE/P DRAM Controller/Host-Hub Interface (rev 02)
00:01.0 PCI bridge: Intel Corporation 82865G/PE/P PCI to AGP Controller (rev 02)
00:06.0 System peripheral: Intel Corporation 82865G/PE/P Processor to I/O Memory Interface (rev 02)
00:1d.0 USB Controller: Intel Corporation 82801EB/ER (ICH5/ICH5R) USB UHCI Controller #1 (rev 02)
00:1d.1 USB Controller: Intel Corporation 82801EB/ER (ICH5/ICH5R) USB UHCI Controller #2 (rev 02)
00:1d.2 USB Controller: Intel Corporation 82801EB/ER (ICH5/ICH5R) USB UHCI Controller #3 (rev 02)
00:1d.3 USB Controller: Intel Corporation 82801EB/ER (ICH5/ICH5R) USB UHCI Controller #4 (rev 02)
00:1d.7 USB Controller: Intel Corporation 82801EB/ER (ICH5/ICH5R) USB2 EHCI Controller (rev 02)
00:1e.0 PCI bridge: Intel Corporation 82801 PCI Bridge (rev c2)
00:1f.0 ISA bridge: Intel Corporation 82801EB/ER (ICH5/ICH5R) LPC Interface Bridge (rev 02)
00:1f.1 IDE interface: Intel Corporation 82801EB/ER (ICH5/ICH5R) IDE Controller (rev 02)
00:1f.2 IDE interface: Intel Corporation 82801EB (ICH5) SATA Controller (rev 02)
00:1f.3 SMBus: Intel Corporation 82801EB/ER (ICH5/ICH5R) SMBus Controller (rev 02)
01:00.0 VGA compatible controller: nVidia Corporation NV34 [GeForce FX 5200] (rev a1)
02:03.0 Serial controller: NetMos Technology PCI 9865 Multi-I/O Controller
02:03.1 Serial controller: NetMos Technology PCI 9865 Multi-I/O Controller
02:03.2 Parallel controller: NetMos Technology PCI 9865 Multi-I/O Controller
a ešte dmesg:
[ 0.000000] .data : 0xc056ecbc - 0xc0750e68 (1928 kB)
[ 0.000000] .text : 0xc0100000 - 0xc056ecbc (4539 kB)
[ 0.000000] Checking if this processor honours the WP bit even in supervisor mode...Ok.
[ 0.000000] SLUB: Genslabs=13, HWalign=128, Order=0-3, MinObjects=0, CPUs=2, Nodes=1
[ 0.000000] Hierarchical RCU implementation.
[ 0.000000] NR_IRQS:2304 nr_irqs:424
[ 0.000000] I-pipe 2.6-03: pipeline enabled.
[ 0.000000] Console: colour VGA+ 80x25
[ 0.000000] console [tty0] enabled
[ 0.000000] Fast TSC calibration using PIT
[ 0.000000] Detected 2422.790 MHz processor.
[ 0.004008] Calibrating delay loop (skipped), value calculated using timer frequency.. 4845.58 BogoMIPS (lpj=9691160)
[ 0.004047] Security Framework initialized
[ 0.004086] AppArmor: AppArmor initialized
[ 0.004109] Mount-cache hash table entries: 512
[ 0.004396] Initializing cgroup subsys ns
[ 0.004409] Initializing cgroup subsys cpuacct
[ 0.004419] Initializing cgroup subsys memory
[ 0.004435] Initializing cgroup subsys devices
[ 0.004440] Initializing cgroup subsys freezer
[ 0.004445] Initializing cgroup subsys net_cls
[ 0.004495] CPU: Trace cache: 12K uops, L1 D cache: 8K
[ 0.004503] CPU: L2 cache: 128K
[ 0.004508] CPU: Hyper-Threading is disabled
[ 0.004515] mce: CPU supports 4 MCE banks
[ 0.004532] CPU0: Thermal monitoring enabled (TM1)
[ 0.004553] Performance Events: no PMU driver, software events only.
[ 0.004568] Checking 'hlt' instruction... OK.
[ 0.021339] SMP alternatives: switching to UP code
[ 0.035018] ACPI: Core revision 20090903
[ 0.045891] ftrace: converting mcount calls to 0f 1f 44 00 00
[ 0.045904] ftrace: allocating 21003 entries in 42 pages
[ 0.059565] Enabling APIC mode: Flat. Using 1 I/O APICs
[ 0.059884] ..TIMER: vector=0x30 apic1=0 pin1=2 apic2=-1 pin2=-1
[ 0.060001] ..MP-BIOS bug: 8254 timer not connected to IO-APIC
[ 0.060001] ...trying to set up timer (IRQ0) through the 8259A ...
[ 0.060001] ..... (found apic 0 pin 2) ...
[ 0.103332] ....... works.
[ 0.103339] CPU0: Intel(R) Celeron(R) CPU 2.40GHz stepping 09
[ 0.104001] Brought up 1 CPUs
[ 0.104001] Total of 1 processors activated (4845.58 BogoMIPS).
[ 0.104001] CPU0 attaching NULL sched-domain.
[ 0.104001] devtmpfs: initialized
[ 0.104001] regulator: core version 0.5
[ 0.104001] NET: Registered protocol family 16
[ 0.104001] EISA bus registered
[ 0.104001] ACPI: bus type pci registered
[ 0.104001] PCI: PCI BIOS revision 2.10 entry at 0xfdb81, last bus=2
[ 0.104001] PCI: Using configuration type 1 for base access
[ 0.105746] bio: create slab <bio-0> at 0
[ 0.106863] ACPI: EC: Look up EC in DSDT
[ 0.115611] ACPI: Interpreter enabled
[ 0.115617] ACPI: (supports S0 S5)
[ 0.115639] ACPI: Using IOAPIC for interrupt routing
[ 0.124471] ACPI: Power Resource [URP1] (off)
[ 0.124555] ACPI: Power Resource [URP2] (off)
[ 0.124655] ACPI: Power Resource [FDDP] (off)
[ 0.124741] ACPI: Power Resource [LPTP] (off)
[ 0.124988] ACPI: No dock devices found.
[ 0.125264] ACPI: PCI Root Bridge [PCI0] (0000:00)
[ 0.125357] pci 0000:00:00.0: Enabling MCH 'Overflow' Device
[ 0.125376] pci 0000:00:00.0: reg 10 32bit mmio pref: [0xf0000000-0xf7ffffff]
[ 0.125515] pci 0000:00:06.0: reg 10 32bit mmio: [0xfecf0000-0xfecf0fff]
[ 0.125638] pci 0000:00:1d.0: reg 20 io port: [0xcc00-0xcc1f]
[ 0.125707] pci 0000:00:1d.1: reg 20 io port: [0xd000-0xd01f]
[ 0.125775] pci 0000:00:1d.2: reg 20 io port: [0xd400-0xd41f]
[ 0.125843] pci 0000:00:1d.3: reg 20 io port: [0xd800-0xd81f]
[ 0.125918] pci 0000:00:1d.7: reg 10 32bit mmio: [0xfebffc00-0xfebfffff]
[ 0.125990] pci 0000:00:1d.7: PME# supported from D0 D3hot D3cold
[ 0.125998] pci 0000:00:1d.7: PME# disabled
[ 0.126110] pci 0000:00:1f.0: quirk: region 0800-087f claimed by ICH4 ACPI/GPIO/TCO
[ 0.126116] pci 0000:00:1f.0: quirk: region 0400-043f claimed by ICH4 GPIO
[ 0.126159] pci 0000:00:1f.1: reg 10 io port: [0x00-0x07]
[ 0.126170] pci 0000:00:1f.1: reg 14 io port: [0x00-0x03]
[ 0.126179] pci 0000:00:1f.1: reg 18 io port: [0x00-0x07]
[ 0.126188] pci 0000:00:1f.1: reg 1c io port: [0x00-0x03]
[ 0.126197] pci 0000:00:1f.1: reg 20 io port: [0xfc00-0xfc0f]
[ 0.126206] pci 0000:00:1f.1: reg 24 32bit mmio: [0x000000-0x0003ff]
[ 0.126248] pci 0000:00:1f.2: reg 10 io port: [0xec00-0xec07]
[ 0.126258] pci 0000:00:1f.2: reg 14 io port: [0xe800-0xe803]
[ 0.126267] pci 0000:00:1f.2: reg 18 io port: [0xe400-0xe407]
[ 0.126276] pci 0000:00:1f.2: reg 1c io port: [0xe000-0xe003]
[ 0.126285] pci 0000:00:1f.2: reg 20 io port: [0xdc00-0xdc0f]
[ 0.126352] pci 0000:00:1f.3: reg 20 io port: [0xc00-0xc1f]
[ 0.126429] pci 0000:01:00.0: reg 10 32bit mmio: [0xfd000000-0xfdffffff]
[ 0.126439] pci 0000:01:00.0: reg 14 32bit mmio pref: [0xe0000000-0xe7ffffff]
[ 0.126464] pci 0000:01:00.0: reg 30 32bit mmio pref: [0xfe9e0000-0xfe9fffff]
[ 0.126539] pci 0000:00:01.0: bridge 32bit mmio: [0xfc900000-0xfe9fffff]
[ 0.126546] pci 0000:00:01.0: bridge 32bit mmio pref: [0xdff00000-0xefefffff]
[ 0.126597] pci 0000:02:03.0: reg 10 io port: [0xb000-0xb007]
[ 0.126608] pci 0000:02:03.0: reg 14 32bit mmio: [0xfeafb000-0xfeafbfff]
[ 0.126630] pci 0000:02:03.0: reg 20 32bit mmio: [0xfeafa000-0xfeafafff]
[ 0.126666] pci 0000:02:03.0: PME# supported from D0 D3cold
[ 0.126672] pci 0000:02:03.0: PME# disabled
[ 0.126714] pci 0000:02:03.1: reg 10 io port: [0xb400-0xb407]
[ 0.126725] pci 0000:02:03.1: reg 14 32bit mmio: [0xfeafd000-0xfeafdfff]
[ 0.126745] pci 0000:02:03.1: reg 20 32bit mmio: [0xfeafc000-0xfeafcfff]
[ 0.126780] pci 0000:02:03.1: PME# supported from D0 D3cold
[ 0.126786] pci 0000:02:03.1: PME# disabled
[ 0.126828] pci 0000:02:03.2: reg 10 io port: [0xbc00-0xbc07]
[ 0.126840] pci 0000:02:03.2: reg 14 io port: [0xb800-0xb807]
[ 0.126850] pci 0000:02:03.2: reg 18 32bit mmio: [0xfeaff000-0xfeafffff]
[ 0.126864] pci 0000:02:03.2: reg 20 32bit mmio: [0xfeafe000-0xfeafefff]
[ 0.126899] pci 0000:02:03.2: PME# supported from D0 D3cold
[ 0.126905] pci 0000:02:03.2: PME# disabled
[ 0.126961] pci 0000:00:1e.0: transparent bridge
[ 0.126968] pci 0000:00:1e.0: bridge io port: [0xb000-0xbfff]
[ 0.126975] pci 0000:00:1e.0: bridge 32bit mmio: [0xfea00000-0xfeafffff]
[ 0.126995] pci_bus 0000:00: on NUMA node 0
[ 0.127010] ACPI: PCI Interrupt Routing Table [\_SB_.PCI0._PRT]
[ 0.127240] ACPI: PCI Interrupt Routing Table [\_SB_.PCI0.ICHB._PRT]
[ 0.132510] ACPI: PCI Interrupt Link [LNKA] (IRQs 3 4 6 7 10 *11 12 14 15)
[ 0.132727] ACPI: PCI Interrupt Link [LNKB] (IRQs 3 4 6 7 *10 11 12 14 15)
[ 0.132936] ACPI: PCI Interrupt Link [LNKC] (IRQs 3 4 6 7 *10 11 12 14 15)
[ 0.133231] ACPI: PCI Interrupt Link [LNKD] (IRQs *3 4 6 7 10 11 12 14 15)
[ 0.133443] ACPI: PCI Interrupt Link [LNKE] (IRQs 3 4 6 7 10 11 12 14 15) *0, disabled.
[ 0.133657] ACPI: PCI Interrupt Link [LNKF] (IRQs 3 4 6 7 10 11 12 14 15) *0, disabled.
[ 0.133869] ACPI: PCI Interrupt Link [LNKG] (IRQs 3 4 6 7 10 11 12 14 15) *0, disabled.
[ 0.134158] ACPI: PCI Interrupt Link [LNKH] (IRQs 3 4 *5 6 7 12 14 15)
[ 0.134430] vgaarb: device added: PCI:0000:01:00.0,decodes=io+mem,owns=io+mem,locks=none
[ 0.134441] vgaarb: loaded
[ 0.134722] SCSI subsystem initialized
[ 0.134907] libata version 3.00 loaded.
[ 0.135156] usbcore: registered new interface driver usbfs
[ 0.135189] usbcore: registered new interface driver hub
[ 0.135303] usbcore: registered new device driver usb
[ 0.135732] ACPI: WMI: Mapper loaded
[ 0.135738] PCI: Using ACPI for IRQ routing
[ 0.136075] NetLabel: Initializing
[ 0.136083] NetLabel: domain hash size = 128
[ 0.136085] NetLabel: protocols = UNLABELED CIPSOv4
[ 0.136112] NetLabel: unlabeled traffic allowed by default
[ 0.136224] Switching to clocksource tsc
[ 0.139563] AppArmor: AppArmor Filesystem Enabled
[ 0.139592] pnp: PnP ACPI init
[ 0.139625] ACPI: bus type pnp registered
[ 0.144592] pnp: PnP ACPI: found 12 devices
[ 0.144599] ACPI: ACPI bus type pnp unregistered
[ 0.144607] PnPBIOS: Disabled by ACPI PNP
[ 0.144640] system 00:01: ioport range 0x290-0x297 has been reserved
[ 0.144647] system 00:01: ioport range 0x3f0-0x3f1 has been reserved
[ 0.144653] system 00:01: ioport range 0x4d0-0x4d1 has been reserved
[ 0.144657] system 00:01: ioport range 0x400-0x43f has been reserved
[ 0.144664] system 00:01: iomem range 0xfed20000-0xfed8ffff has been reserved
[ 0.144669] system 00:01: iomem range 0xfee00000-0xfee00fff has been reserved
[ 0.179716] pci 0000:00:01.0: PCI bridge, secondary bus 0000:01
[ 0.179722] pci 0000:00:01.0: IO window: disabled
[ 0.179731] pci 0000:00:01.0: MEM window: 0xfc900000-0xfe9fffff
[ 0.179738] pci 0000:00:01.0: PREFETCH window: 0xdff00000-0xefefffff
[ 0.179748] pci 0000:00:1e.0: PCI bridge, secondary bus 0000:02
[ 0.179753] pci 0000:00:1e.0: IO window: 0xb000-0xbfff
[ 0.179761] pci 0000:00:1e.0: MEM window: 0xfea00000-0xfeafffff
[ 0.179766] pci 0000:00:1e.0: PREFETCH window: disabled
[ 0.179794] pci 0000:00:1e.0: setting latency timer to 64
[ 0.179803] pci_bus 0000:00: resource 0 io: [0x00-0xffff]
[ 0.179807] pci_bus 0000:00: resource 1 mem: [0x000000-0xffffffff]
[ 0.179814] pci_bus 0000:01: resource 1 mem: [0xfc900000-0xfe9fffff]
[ 0.179817] pci_bus 0000:01: resource 2 pref mem [0xdff00000-0xefefffff]
[ 0.179822] pci_bus 0000:02: resource 0 io: [0xb000-0xbfff]
[ 0.179825] pci_bus 0000:02: resource 1 mem: [0xfea00000-0xfeafffff]
[ 0.179829] pci_bus 0000:02: resource 3 io: [0x00-0xffff]
[ 0.179833] pci_bus 0000:02: resource 4 mem: [0x000000-0xffffffff]
[ 0.179892] NET: Registered protocol family 2
[ 0.180061] IP route cache hash table entries: 32768 (order: 5, 131072 bytes)
[ 0.180671] TCP established hash table entries: 131072 (order: 8, 1048576 bytes)
[ 0.182264] TCP bind hash table entries: 65536 (order: 7, 524288 bytes)
[ 0.183073] TCP: Hash tables configured (established 131072 bind 65536)
[ 0.183079] TCP reno registered
[ 0.183297] NET: Registered protocol family 1
[ 0.183452] pci 0000:01:00.0: Boot video device
[ 0.183877] Scanning for low memory corruption every 60 seconds
[ 0.184077] audit: initializing netlink socket (disabled)
[ 0.184108] type=2000 audit(1358686259.183:1): initialized
[ 0.192185] Trying to unpack rootfs image as initramfs...
[ 0.204228] highmem bounce pool size: 64 pages
[ 0.204242] HugeTLB registered 4 MB page size, pre-allocated 0 pages
[ 0.206733] VFS: Disk quotas dquot_6.5.2
[ 0.206868] Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
[ 0.208241] fuse init (API version 7.13)
[ 0.208496] msgmni has been set to 1706
[ 0.212058] alg: No test for stdrng (krng)
[ 0.212253] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 253)
[ 0.212260] io scheduler noop registered
[ 0.212263] io scheduler anticipatory registered
[ 0.212266] io scheduler deadline registered
[ 0.212368] io scheduler cfq registered (default)
[ 0.212613] pci_hotplug: PCI Hot Plug PCI Core version: 0.5
[ 0.212665] pciehp: PCI Express Hot Plug Controller Driver version: 0.4
[ 0.212811] input: Power Button as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0C:00/input/input0
[ 0.212821] ACPI: Power Button [PWRB]
[ 0.212934] input: Power Button as /devices/LNXSYSTM:00/LNXPWRBN:00/input/input1
[ 0.212943] ACPI: Power Button [PWRF]
[ 0.220230] isapnp: Scanning for PnP cards...
[ 0.227454] Serial: 8250/16550 driver, 4 ports, IRQ sharing enabled
[ 0.227592] serial8250: ttyS0 at I/O 0x3f8 (irq = 4) is a 16550A
[ 0.228419] 00:0a: ttyS0 at I/O 0x3f8 (irq = 4) is a 16550A
[ 0.228604] alloc irq_desc for 19 on node -1
[ 0.228611] alloc kstat_irqs on node -1
[ 0.228625] serial 0000:02:03.0: PCI INT A -> GSI 19 (level, low) -> IRQ 19
[ 0.228637] serial 0000:02:03.0: PCI INT A disabled
[ 0.228672] alloc irq_desc for 16 on node -1
[ 0.228677] alloc kstat_irqs on node -1
[ 0.228685] serial 0000:02:03.1: PCI INT B -> GSI 16 (level, low) -> IRQ 16
[ 0.228694] serial 0000:02:03.1: PCI INT B disabled
[ 0.231065] brd: module loaded
[ 0.280305] loop: module loaded
[ 0.280559] input: Macintosh mouse button emulation as /devices/virtual/input/input2
[ 0.280797] ata_piix 0000:00:1f.1: version 2.13
[ 0.280820] ata_piix 0000:00:1f.1: enabling device (0005 -> 0007)
[ 0.280834] alloc irq_desc for 18 on node -1
[ 0.280838] alloc kstat_irqs on node -1
[ 0.280852] ata_piix 0000:00:1f.1: PCI INT A -> GSI 18 (level, low) -> IRQ 18
[ 0.280939] ata_piix 0000:00:1f.1: setting latency timer to 64
[ 0.283718] scsi0 : ata_piix
[ 0.284000] scsi1 : ata_piix
[ 0.286493] ata1: PATA max UDMA/100 cmd 0x1f0 ctl 0x3f6 bmdma 0xfc00 irq 14
[ 0.286500] ata2: PATA max UDMA/100 cmd 0x170 ctl 0x376 bmdma 0xfc08 irq 15
[ 0.286651] ata_piix 0000:00:1f.2: PCI INT A -> GSI 18 (level, low) -> IRQ 18
[ 0.286663] ata_piix 0000:00:1f.2: MAP [ P0 -- P1 -- ]
[ 0.286748] ata_piix 0000:00:1f.2: setting latency timer to 64
[ 0.291790] scsi2 : ata_piix
[ 0.292296] scsi3 : ata_piix
[ 0.292406] ata3: SATA max UDMA/133 cmd 0xec00 ctl 0xe800 bmdma 0xdc00 irq 18
[ 0.292413] ata4: SATA max UDMA/133 cmd 0xe400 ctl 0xe000 bmdma 0xdc08 irq 18
[ 0.293197] Fixed MDIO Bus: probed
[ 0.293279] PPP generic driver version 2.4.2
[ 0.293410] tun: Universal TUN/TAP device driver, 1.6
[ 0.293416] tun: (C) 1999-2004 Max Krasnyansky <maxk@qualcomm.com>
[ 0.293686] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[ 0.293745] alloc irq_desc for 23 on node -1
[ 0.293751] alloc kstat_irqs on node -1
[ 0.293765] ehci_hcd 0000:00:1d.7: PCI INT D -> GSI 23 (level, low) -> IRQ 23
[ 0.293794] ehci_hcd 0000:00:1d.7: setting latency timer to 64
[ 0.293801] ehci_hcd 0000:00:1d.7: EHCI Host Controller
[ 0.293922] ehci_hcd 0000:00:1d.7: new USB bus registered, assigned bus number 1
[ 0.293981] ehci_hcd 0000:00:1d.7: debug port 1
[ 0.297872] ehci_hcd 0000:00:1d.7: cache line size of 128 is not supported
[ 0.304069] ehci_hcd 0000:00:1d.7: irq 23, io mem 0xfebffc00
[ 0.319705] ehci_hcd 0000:00:1d.7: USB 2.0 started, EHCI 1.00
[ 0.319997] usb usb1: configuration #1 chosen from 1 choice
[ 0.320069] hub 1-0:1.0: USB hub found
[ 0.320096] hub 1-0:1.0: 8 ports detected
[ 0.320225] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[ 0.320264] uhci_hcd: USB Universal Host Controller Interface driver
[ 0.320352] uhci_hcd 0000:00:1d.0: PCI INT A -> GSI 16 (level, low) -> IRQ 16
[ 0.320372] uhci_hcd 0000:00:1d.0: setting latency timer to 64
[ 0.320378] uhci_hcd 0000:00:1d.0: UHCI Host Controller
[ 0.320528] uhci_hcd 0000:00:1d.0: new USB bus registered, assigned bus number 2
[ 0.320585] uhci_hcd 0000:00:1d.0: irq 16, io base 0x0000cc00
[ 0.320816] usb usb2: configuration #1 chosen from 1 choice
[ 0.320885] hub 2-0:1.0: USB hub found
[ 0.320912] hub 2-0:1.0: 2 ports detected
[ 0.321019] uhci_hcd 0000:00:1d.1: PCI INT B -> GSI 19 (level, low) -> IRQ 19
[ 0.321039] uhci_hcd 0000:00:1d.1: setting latency timer to 64
[ 0.321044] uhci_hcd 0000:00:1d.1: UHCI Host Controller
[ 0.321167] uhci_hcd 0000:00:1d.1: new USB bus registered, assigned bus number 3
[ 0.321222] uhci_hcd 0000:00:1d.1: irq 19, io base 0x0000d000
[ 0.321446] usb usb3: configuration #1 chosen from 1 choice
[ 0.321512] hub 3-0:1.0: USB hub found
[ 0.321539] hub 3-0:1.0: 2 ports detected
[ 0.321652] uhci_hcd 0000:00:1d.2: PCI INT C -> GSI 18 (level, low) -> IRQ 18
[ 0.321672] uhci_hcd 0000:00:1d.2: setting latency timer to 64
[ 0.321678] uhci_hcd 0000:00:1d.2: UHCI Host Controller
[ 0.321803] uhci_hcd 0000:00:1d.2: new USB bus registered, assigned bus number 4
[ 0.321844] uhci_hcd 0000:00:1d.2: irq 18, io base 0x0000d400
[ 0.322079] usb usb4: configuration #1 chosen from 1 choice
[ 0.322149] hub 4-0:1.0: USB hub found
[ 0.322177] hub 4-0:1.0: 2 ports detected
[ 0.322282] uhci_hcd 0000:00:1d.3: PCI INT A -> GSI 16 (level, low) -> IRQ 16
[ 0.322301] uhci_hcd 0000:00:1d.3: setting latency timer to 64
[ 0.322306] uhci_hcd 0000:00:1d.3: UHCI Host Controller
[ 0.322447] uhci_hcd 0000:00:1d.3: new USB bus registered, assigned bus number 5
[ 0.322489] uhci_hcd 0000:00:1d.3: irq 16, io base 0x0000d800
[ 0.322724] usb usb5: configuration #1 chosen from 1 choice
[ 0.322792] hub 5-0:1.0: USB hub found
[ 0.322818] hub 5-0:1.0: 2 ports detected
[ 0.323020] PNP: PS/2 Controller [PNP0303:PS2K,PNP0f13:PS2M] at 0x60,0x64 irq 1,12
[ 0.329413] serio: i8042 KBD port at 0x60,0x64 irq 1
[ 0.329439] serio: i8042 AUX port at 0x60,0x64 irq 12
[ 0.329868] mice: PS/2 mouse device common for all mice
[ 0.330226] rtc_cmos 00:04: RTC can wake from S4
[ 0.330360] rtc_cmos 00:04: rtc core: registered rtc_cmos as rtc0
[ 0.330398] rtc0: alarms up to one month, y3k, 114 bytes nvram
[ 0.330655] device-mapper: uevent: version 1.0.3
[ 0.335757] device-mapper: ioctl: 4.15.0-ioctl (2009-04-01) initialised: dm-devel@redhat.com
[ 0.335989] device-mapper: multipath: version 1.1.0 loaded
[ 0.335997] device-mapper: multipath round-robin: version 1.0.0 loaded
[ 0.336376] EISA: Probing bus 0 at eisa.0
[ 0.336422] EISA: Detected 0 cards.
[ 0.336428] cpuidle: using governor ladder
[ 0.336432] cpuidle: using governor menu
[ 0.337175] TCP cubic registered
[ 0.337474] NET: Registered protocol family 10
[ 0.338363] lo: Disabled Privacy Extensions
[ 0.338877] NET: Registered protocol family 17
[ 0.338967] Using IPI No-Shortcut mode
[ 0.339265] registered taskstats version 1
[ 0.343340] rtc_cmos 00:04: setting system clock to 2013-01-20 12:50:59 UTC (1358686259)
[ 0.343351] BIOS EDD facility v0.16 2004-Jun-25, 0 devices found
[ 0.343353] EDD information not available.
[ 0.400493] input: AT Translated Set 2 keyboard as /devices/platform/i8042/serio0/input/input3
[ 0.423744] hub 4-0:1.0: over-current change on port 1
[ 0.495170] ata3.00: ATA-9: INTEL SSDSC2CT060A3, 300i, max UDMA/133
[ 0.495178] ata3.00: 117231408 sectors, multi 16: LBA48 NCQ (depth 0/32)
[ 0.508462] ata3.00: configured for UDMA/133
[ 0.535718] hub 4-0:1.0: over-current change on port 2
[ 0.667518] hub 5-0:1.0: over-current change on port 1
[ 0.768198] hub 5-0:1.0: over-current change on port 2
[ 0.927701] isapnp: No Plug & Play device found
[ 0.928280] scsi 2:0:0:0: Direct-Access ATA INTEL SSDSC2CT06 300i PQ: 0 ANSI: 5
[ 0.928665] sd 2:0:0:0: Attached scsi generic sg0 type 0
[ 0.928975] sd 2:0:0:0: [sda] 117231408 512-byte logical blocks: (60.0 GB/55.8 GiB)
[ 0.929166] sd 2:0:0:0: [sda] Write Protect is off
[ 0.929173] sd 2:0:0:0: [sda] Mode Sense: 00 3a 00 00
[ 0.929269] sd 2:0:0:0: [sda] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
[ 0.929791] sda: sda1 sda2 < sda5 >
[ 0.931972] sd 2:0:0:0: [sda] Attached SCSI disk
[ 0.983708] usb 1-2: new high speed USB device using ehci_hcd and address 2
[ 1.156385] Freeing initrd memory: 12829k freed
[ 1.178830] Freeing unused kernel memory: 620k freed
[ 1.179953] Write protecting the kernel text: 4540k
[ 1.179989] Write protecting the kernel read-only data: 1668k
[ 1.240588] udev: starting version 151
[ 1.273675] usb 1-2: configuration #1 chosen from 1 choice
[ 1.384111] usb 1-3: new high speed USB device using ehci_hcd and address 3
[ 1.519114] usb 1-3: configuration #1 chosen from 1 choice
[ 1.680713] FDC 0 is a post-1991 82077
[ 1.778591] Initializing USB Mass Storage driver...
[ 1.787477] scsi4 : SCSI emulation for USB Mass Storage devices
[ 1.792170] usbcore: registered new interface driver usb-storage
[ 1.792178] USB Mass Storage support registered.
[ 1.796229] usb-storage: device found at 3
[ 1.796235] usb-storage: waiting for device to settle before scanning
[ 1.796309] Linux agpgart interface v0.103
[ 1.836327] agpgart-intel 0000:00:00.0: Intel 865 Chipset
[ 1.890252] agpgart-intel 0000:00:00.0: AGP aperture is 128M @ 0xf0000000
[ 1.948135] [drm] Initialized drm 1.1.0 20060810
[ 2.001568] nouveau 0000:01:00.0: PCI INT A -> GSI 16 (level, low) -> IRQ 16
[ 2.006943] [drm] nouveau 0000:01:00.0: Detected an NV30 generation card (0x034200b1)
[ 2.007052] [drm] nouveau 0000:01:00.0: Attempting to load BIOS image from PROM
[ 2.149380] [drm] nouveau 0000:01:00.0: ... appears to be valid
[ 2.149523] [drm] nouveau 0000:01:00.0: BMP BIOS found
[ 2.149528] [drm] nouveau 0000:01:00.0: BMP version 5.41
[ 2.149533] [drm] nouveau 0000:01:00.0: Bios version 04.34.20.87
[ 2.149538] [drm] nouveau 0000:01:00.0: Found Display Configuration Block version 2.2
[ 2.149544] [drm] nouveau 0000:01:00.0: Raw DCB entry 0: 01000300 000088b8
[ 2.149550] [drm] nouveau 0000:01:00.0: Raw DCB entry 1: 01010312 00008800
[ 2.149554] [drm] nouveau 0000:01:00.0: Raw DCB entry 2: 02020321 00000303
[ 2.149664] [drm] nouveau 0000:01:00.0: Loading NV17 power sequencing microcode
[ 2.149670] [drm] nouveau 0000:01:00.0: Parsing VBIOS init table 0 at offset 0xED03
[ 2.164055] [drm] nouveau 0000:01:00.0: Parsing VBIOS init table 1 at offset 0xEF9E
[ 2.164071] [drm] nouveau 0000:01:00.0: Parsing VBIOS init table 2 at offset 0xF0E4
[ 2.164117] [drm] nouveau 0000:01:00.0: Parsing VBIOS init table 3 at offset 0xF26D
[ 2.164124] [drm] nouveau 0000:01:00.0: Parsing VBIOS init table 4 at offset 0xF28A
[ 2.164131] [drm] nouveau 0000:01:00.0: Parsing VBIOS init table 5 at offset 0xF2A7
[ 2.172048] [drm] nouveau 0000:01:00.0: Parsing VBIOS init table 6 at offset 0xF440
[ 2.186669] [TTM] Zone kernel: Available graphics memory: 443626 kiB.
[ 2.186676] [TTM] Zone highmem: Available graphics memory: 513230 kiB.
[ 2.186699] [drm] nouveau 0000:01:00.0: 128 MiB VRAM
[ 2.186780] agpgart-intel 0000:00:00.0: AGP 3.0 bridge
[ 2.186802] agpgart: modprobe tried to set rate=x12. Setting to AGP3 x8 mode.
[ 2.186815] agpgart-intel 0000:00:00.0: putting AGP V3 device into 8x mode
[ 2.186861] nouveau 0000:01:00.0: putting AGP V3 device into 8x mode
[ 2.186887] [drm] nouveau 0000:01:00.0: 128 MiB GART (aperture)
[ 2.187188] [drm] nouveau 0000:01:00.0: Allocating FIFO number 0
[ 2.188438] [drm] nouveau 0000:01:00.0: nouveau_channel_alloc: initialised FIFO 0
[ 2.188458] [drm] nouveau 0000:01:00.0: Initial CRTC_OWNER is 0
[ 2.188468] [drm] nouveau 0000:01:00.0: Saving VGA fonts
[ 2.241868] [drm] nouveau 0000:01:00.0: Detected a VGA connector
[ 2.242280] [drm] nouveau 0000:01:00.0: Detected a DVI-D connector
[ 2.242641] [drm] nouveau 0000:01:00.0: Detected a TV connector
[ 2.244447] [drm] nouveau 0000:01:00.0: Setting dpms mode 3 on vga encoder (output 0)
[ 2.244456] [drm] nouveau 0000:01:00.0: Setting dpms mode 3 on tmds encoder (output 1)
[ 2.244462] [drm] nouveau 0000:01:00.0: Setting dpms mode 3 on TV encoder (output 2)
[ 2.400281] [drm] nouveau 0000:01:00.0: allocated 1280x1024 fb: 0x49000, bo f696a800
[ 2.400636] fb0: nouveaufb frame buffer device
[ 2.400642] registered panic notifier
[ 2.400657] [drm] Initialized nouveau 0.0.15 20090420 for 0000:01:00.0 on minor 0
[ 2.406272] vga16fb: initializing
[ 2.406283] vga16fb: mapped to 0xc00a0000
[ 2.406292] vga16fb: not registering due to another framebuffer present
[ 2.439575] [drm] nouveau 0000:01:00.0: Setting dpms mode 0 on vga encoder (output 0)
[ 2.439585] [drm] nouveau 0000:01:00.0: Output VGA-1 is running on CRTC 0 using output A
[ 2.448798] Console: switching to colour frame buffer device 160x64
[ 2.972957] xor: automatically using best checksumming function: pIII_sse
[ 2.992019] pIII_sse : 3178.000 MB/sec
[ 2.992025] xor: using function: pIII_sse (3178.000 MB/sec)
[ 2.997936] device-mapper: dm-raid45: initialized v0.2594b
[ 3.076109] EXT4-fs (sda1): mounted filesystem with ordered data mode
[ 3.660378] Adding 2438136k swap on /dev/sda5. Priority:-1 extents:1 across:2438136k SS
[ 3.963521] udev: starting version 151
[ 4.494360] lp: driver loaded but no devices found
[ 4.628640] shpchp: Standard Hot Plug PCI Controller Driver version: 0.4
[ 4.783026] parport_pc 00:0b: reported by Plug and Play ACPI
[ 4.783058] parport0: PC-style at 0x378, irq 7 [PCSPP,TRISTATE,EPP]
[ 4.821810] intel_rng: FWH not detected
[ 4.861021] lp0: using parport0 (interrupt-driven).
[ 5.229473] psmouse serio1: ID: 10 00 64
[ 5.451507] ppdev: user-space parallel port driver
[ 5.462056] cfg80211: Calling CRDA to update world regulatory domain
[ 5.568975] input: ImPS/2 Generic Wheel Mouse as /devices/platform/i8042/serio1/input/input4
[ 5.655610] cfg80211: World regulatory domain updated:
[ 5.655618] (start_freq - end_freq @ bandwidth), (max_antenna_gain, max_eirp)
[ 5.655623] (2402000 KHz - 2472000 KHz @ 40000 KHz), (300 mBi, 2000 mBm)
[ 5.655628] (2457000 KHz - 2482000 KHz @ 20000 KHz), (300 mBi, 2000 mBm)
[ 5.655632] (2474000 KHz - 2494000 KHz @ 20000 KHz), (300 mBi, 2000 mBm)
[ 5.655636] (5170000 KHz - 5250000 KHz @ 40000 KHz), (300 mBi, 2000 mBm)
[ 5.655641] (5735000 KHz - 5835000 KHz @ 40000 KHz), (300 mBi, 2000 mBm)
[ 5.949139] phy0 -> rt2500usb_init_eeprom: Error - Invalid RT chipset detected.
[ 5.949152] phy0 -> rt2x00lib_probe_dev: Error - Failed to allocate device.
[ 5.949258] usbcore: registered new interface driver rt2500usb
[ 6.056343] type=1505 audit(1358686265.212:2): operation="profile_load" pid=588 name="/sbin/dhclient3"
[ 6.057088] type=1505 audit(1358686265.212:3): operation="profile_load" pid=588 name="/usr/lib/NetworkManager/nm-dhcp-client.action"
[ 6.057507] type=1505 audit(1358686265.212:4): operation="profile_load" pid=588 name="/usr/lib/connman/scripts/dhclient-script"
[ 6.449172] phy1: Selected rate control algorithm 'minstrel'
[ 6.450457] Registered led device: rt73usb-phy1::radio
[ 6.450510] Registered led device: rt73usb-phy1::assoc
[ 6.450556] Registered led device: rt73usb-phy1::quality
[ 6.451844] usbcore: registered new interface driver rt73usb
[ 6.808477] usb-storage: device scan complete
[ 6.809261] scsi 4:0:0:0: Direct-Access Kingston DataTraveler 410 1.00 PQ: 0 ANSI: 2
[ 6.819478] type=1505 audit(1358686265.972:5): operation="profile_load" pid=753 name="/usr/share/gdm/guest-session/Xsession"
[ 6.824913] sd 4:0:0:0: Attached scsi generic sg1 type 0
[ 6.825514] sd 4:0:0:0: [sdb] 15634432 512-byte logical blocks: (8.00 GB/7.45 GiB)
[ 6.826105] rt73usb 1-2:1.0: firmware: requesting rt73.bin
[ 6.826739] sd 4:0:0:0: [sdb] Write Protect is off
[ 6.826748] sd 4:0:0:0: [sdb] Mode Sense: 16 1a 09 51
[ 6.826753] sd 4:0:0:0: [sdb] Assuming drive cache: write through
[ 6.830976] sd 4:0:0:0: [sdb] Assuming drive cache: write through
[ 6.830992] sdb: sdb1
[ 6.852838] sd 4:0:0:0: [sdb] Assuming drive cache: write through
[ 6.852851] sd 4:0:0:0: [sdb] Attached SCSI removable disk
[ 6.917054] type=1505 audit(1358686266.072:6): operation="profile_replace" pid=760 name="/sbin/dhclient3"
[ 6.929603] type=1505 audit(1358686266.084:7): operation="profile_replace" pid=760 name="/usr/lib/NetworkManager/nm-dhcp-client.action"
[ 6.937997] type=1505 audit(1358686266.092:8): operation="profile_replace" pid=760 name="/usr/lib/connman/scripts/dhclient-script"
[ 6.974638] ADDRCONF(NETDEV_UP): wlan0: link is not ready
[ 7.136759] type=1505 audit(1358686266.292:9): operation="profile_load" pid=766 name="/usr/bin/evince"
[ 7.217005] type=1505 audit(1358686266.372:10): operation="profile_load" pid=766 name="/usr/bin/evince-previewer"
[ 7.223608] type=1505 audit(1358686266.376:11): operation="profile_load" pid=766 name="/usr/bin/evince-thumbnailer"
[ 8.215925] [drm] nouveau 0000:01:00.0: Allocating FIFO number 1
[ 8.220326] [drm] nouveau 0000:01:00.0: nouveau_channel_alloc: initialised FIFO 1
[ 35.342479] wlan0: direct probe to AP f8:d1:11:7e:02:b0 (try 1)
[ 35.342541] wlan0: deauthenticating from f8:d1:11:7e:02:b0 by local choice (reason=3)
[ 35.342669] wlan0: direct probe to AP f8:d1:11:7e:02:b0 (try 1)
[ 35.345427] wlan0: direct probe responded
[ 35.345439] wlan0: authenticate with AP f8:d1:11:7e:02:b0 (try 1)
[ 35.355410] wlan0: authenticated
[ 35.355491] wlan0: associate with AP f8:d1:11:7e:02:b0 (try 1)
[ 35.358279] wlan0: RX AssocResp from f8:d1:11:7e:02:b0 (capab=0x431 status=0 aid=1)
[ 35.358286] wlan0: associated
[ 35.373952] ADDRCONF(NETDEV_CHANGE): wlan0: link becomes ready
[ 46.196026] wlan0: no IPv6 routers present
[ 1380.500055] No probe response from AP f8:d1:11:7e:02:b0 after 500ms, disconnecting.
[ 1388.119439] wlan0: direct probe to AP f8:d1:11:7e:02:b0 (try 1)
[ 1388.128878] wlan0: direct probe responded
[ 1388.128898] wlan0: authenticate with AP f8:d1:11:7e:02:b0 (try 1)
[ 1388.134417] wlan0: authenticated
[ 1388.134475] wlan0: associate with AP f8:d1:11:7e:02:b0 (try 1)
[ 1388.141220] wlan0: RX AssocResp from f8:d1:11:7e:02:b0 (capab=0x431 status=0 aid=1)
[ 1388.141227] wlan0: associated
[ 1395.500055] No probe response from AP f8:d1:11:7e:02:b0 after 500ms, disconnecting.
[ 1396.882547] wlan0: direct probe to AP f8:d1:11:7e:02:b0 (try 1)
[ 1397.080075] wlan0: direct probe to AP f8:d1:11:7e:02:b0 (try 2)
[ 1397.280070] wlan0: direct probe to AP f8:d1:11:7e:02:b0 (try 3)
[ 1397.480067] wlan0: direct probe to AP f8:d1:11:7e:02:b0 timed out
[ 1445.675820] wlan0: direct probe to AP f8:d1:11:7e:02:b0 (try 1)
[ 1445.872046] wlan0: direct probe to AP f8:d1:11:7e:02:b0 (try 2)
[ 1446.072088] wlan0: direct probe to AP f8:d1:11:7e:02:b0 (try 3)
[ 1446.272053] wlan0: direct probe to AP f8:d1:11:7e:02:b0 timed out
[ 1475.674263] wlan0: direct probe to AP f8:d1:11:7e:02:b0 (try 1)
[ 1475.679191] wlan0: direct probe responded
[ 1475.679200] wlan0: authenticate with AP f8:d1:11:7e:02:b0 (try 1)
[ 1475.683175] wlan0: authenticated
[ 1475.683232] wlan0: associate with AP f8:d1:11:7e:02:b0 (try 1)
[ 1475.685431] wlan0: RX AssocResp from f8:d1:11:7e:02:b0 (capab=0x431 status=0 aid=1)
[ 1475.685439] wlan0: associated
[ 1651.500058] No probe response from AP f8:d1:11:7e:02:b0 after 500ms, disconnecting.
[ 1665.364413] wlan0: direct probe to AP f8:d1:11:7e:02:b0 (try 1)
[ 1665.375589] wlan0: direct probe responded
[ 1665.375610] wlan0: authenticate with AP f8:d1:11:7e:02:b0 (try 1)
[ 1665.379053] wlan0: authenticated
[ 1665.379108] wlan0: associate with AP f8:d1:11:7e:02:b0 (try 1)
[ 1665.382305] wlan0: RX AssocResp from f8:d1:11:7e:02:b0 (capab=0x431 status=0 aid=1)
[ 1665.382313] wlan0: associated
[ 2084.500050] No probe response from AP f8:d1:11:7e:02:b0 after 500ms, disconnecting.
[ 2104.635244] wlan0: direct probe to AP f8:d1:11:7e:02:b0 (try 1)
[ 2104.638613] wlan0: direct probe responded
[ 2104.638624] wlan0: authenticate with AP f8:d1:11:7e:02:b0 (try 1)
[ 2104.640519] wlan0: authenticated
[ 2104.640604] wlan0: associate with AP f8:d1:11:7e:02:b0 (try 1)
[ 2104.644477] wlan0: RX AssocResp from f8:d1:11:7e:02:b0 (capab=0x431 status=0 aid=1)
[ 2104.644484] wlan0: associated
[ 2188.500043] No probe response from AP f8:d1:11:7e:02:b0 after 500ms, disconnecting.
[ 2214.923858] wlan0: direct probe to AP f8:d1:11:7e:02:b0 (try 1)
[ 2214.926414] wlan0: direct probe responded
[ 2214.926424] wlan0: authenticate with AP f8:d1:11:7e:02:b0 (try 1)
[ 2214.936524] wlan0: authenticated
[ 2214.936594] wlan0: associate with AP f8:d1:11:7e:02:b0 (try 1)
[ 2214.947752] wlan0: RX AssocResp from f8:d1:11:7e:02:b0 (capab=0x431 status=0 aid=1)
[ 2214.947759] wlan0: associated
To je stroj bez paralelniho portu na desce? vypada to tak
jestli jo, tak tady je adresa ty karty a zda se ze podporuje i EPP
Martin
Martin
do emc si ji zapiš takto : OxccOO
PC má paralelny port nastavil som v biose EPP, chcem však viac vstupov preto hned na začiatku musím vedieť či to dokažem v Machu to šlo na druhom porte nastaviť, dakujem za rýchlu reakciu idem skušať.fupe píše:To je stroj bez paralelniho portu na desce? vypada to tak
Martin
dakujem za rýchlu reakciu idem skušať.packa píše:do emc si ji zapiš takto : OxccOO
na test som použil:
http://wiki.linuxcnc.org/cgi-bin/wiki.p ... ort_Tester" onclick="window.open(this.href);return false;
port na doske reaguje bez problemov predstavujem si to tak že v hal subore prepišem cfg="0x378 out" na cfg="0xcc00 out" a budem skusat ale zatial sa s linuxom zoznamujem iba tretí den po pár hodín tak to ide z tuha.
tak som to zrejme nepochopil urobil som toto:packa píše:přesně jak jsi psal , samozřejmě můžeš použít třebA pět portu najednou , jen je odděl čárkama a musíš dopsat další parport , ,máš tam parport0 a další parport1 a tak dál
loadrt hal_parport cfg="0xcc00 out"
loadusr -Wn PortTest pyvcp -c PortTest ptest.xml
loadrt threads name1=porttest period1=1000000
addf parport.1.read porttest
addf parport.1.write porttest
net pin01 PortTest.btn01 parport.1.pin-01-out PortTest.led-01
net pin02 PortTest.btn02 parport.1.pin-02-out PortTest.led-02
net pin03 PortTest.btn03 parport.1.pin-03-out PortTest.led-03
net pin04 PortTest.btn04 parport.1.pin-04-out PortTest.led-04
net pin05 PortTest.btn05 parport.1.pin-05-out PortTest.led-05
net pin06 PortTest.btn06 parport.1.pin-06-out PortTest.led-06
net pin07 PortTest.btn07 parport.1.pin-07-out PortTest.led-07
net pin08 PortTest.btn08 parport.1.pin-08-out PortTest.led-08
net pin09 PortTest.btn09 parport.1.pin-09-out PortTest.led-09
net pin14 PortTest.btn14 parport.1.pin-14-out PortTest.led-14
net pin16 PortTest.btn16 parport.1.pin-16-out PortTest.led-16
net pin17 PortTest.btn17 parport.1.pin-17-out PortTest.led-17
net pin10 parport.1.pin-10-in PortTest.led-10
net pin11 parport.1.pin-11-in PortTest.led-11
net pin12 parport.1.pin-12-in PortTest.led-12
net pin13 parport.1.pin-13-in PortTest.led-13
net pin15 parport.1.pin-15-in PortTest.led-15
start
# loadusr halmeter
a výsledok:
uhy@uhy-desktop:~/Plocha/EMC2/ptest$ halrun -I -f ptest.hal
insmod: error inserting '/usr/realtime-2.6.32-122-rtai/modules/linuxcnc/hal_parport.ko': -1 Device or resource busy
ptest.hal:1: exit value: 1
ptest.hal:1: insmod failed, returned -1
See the output of 'dmesg' for more information.
halcmd:
tak idem bádať
aj pokiaľ to nechám na nule iba zmena adresy hlásenie je to isté:
halcmd:
port mám jeden na doske ten mi funguje bez problemov ako parport.0 preto som si myslel že mám priradiť pre túto pci kartu ako parport.1
takto to vyzerá na parport.0:
halcmd: show
Loaded HAL Components:
ID Type Name PID State
3 User halcmd2047 2047 ready
7 RT threads ready
6 User PortTest 2044 ready
4 RT hal_parport ready
Component Pins:
Owner Type Dir Value Name
6 bit OUT FALSE PortTest.btn01 ==> pin01
6 bit OUT FALSE PortTest.btn02 ==> pin02
6 bit OUT FALSE PortTest.btn03 ==> pin03
6 bit OUT FALSE PortTest.btn04 ==> pin04
6 bit OUT FALSE PortTest.btn05 ==> pin05
6 bit OUT FALSE PortTest.btn06 ==> pin06
6 bit OUT FALSE PortTest.btn07 ==> pin07
6 bit OUT FALSE PortTest.btn08 ==> pin08
6 bit OUT FALSE PortTest.btn09 ==> pin09
6 bit OUT FALSE PortTest.btn14 ==> pin14
6 bit OUT FALSE PortTest.btn16 ==> pin16
6 bit OUT FALSE PortTest.btn17 ==> pin17
6 bit IN FALSE PortTest.led-01 <== pin01
6 bit IN FALSE PortTest.led-02 <== pin02
6 bit IN FALSE PortTest.led-03 <== pin03
6 bit IN FALSE PortTest.led-04 <== pin04
6 bit IN FALSE PortTest.led-05 <== pin05
6 bit IN FALSE PortTest.led-06 <== pin06
6 bit IN FALSE PortTest.led-07 <== pin07
6 bit IN FALSE PortTest.led-08 <== pin08
6 bit IN FALSE PortTest.led-09 <== pin09
6 bit IN TRUE PortTest.led-10 <== pin10
6 bit IN TRUE PortTest.led-11 <== pin11
6 bit IN TRUE PortTest.led-12 <== pin12
6 bit IN TRUE PortTest.led-13 <== pin13
6 bit IN FALSE PortTest.led-14 <== pin14
6 bit IN TRUE PortTest.led-15 <== pin15
6 bit IN FALSE PortTest.led-16 <== pin16
6 bit IN FALSE PortTest.led-17 <== pin17
4 bit IN FALSE parport.0.pin-01-out <== pin01
4 bit IN FALSE parport.0.pin-02-out <== pin02
4 bit IN FALSE parport.0.pin-03-out <== pin03
4 bit IN FALSE parport.0.pin-04-out <== pin04
4 bit IN FALSE parport.0.pin-05-out <== pin05
4 bit IN FALSE parport.0.pin-06-out <== pin06
4 bit IN FALSE parport.0.pin-07-out <== pin07
4 bit IN FALSE parport.0.pin-08-out <== pin08
4 bit IN FALSE parport.0.pin-09-out <== pin09
4 bit OUT TRUE parport.0.pin-10-in ==> pin10
4 bit OUT FALSE parport.0.pin-10-in-not
4 bit OUT TRUE parport.0.pin-11-in ==> pin11
4 bit OUT FALSE parport.0.pin-11-in-not
4 bit OUT TRUE parport.0.pin-12-in ==> pin12
4 bit OUT FALSE parport.0.pin-12-in-not
4 bit OUT TRUE parport.0.pin-13-in ==> pin13
4 bit OUT FALSE parport.0.pin-13-in-not
4 bit IN FALSE parport.0.pin-14-out <== pin14
4 bit OUT TRUE parport.0.pin-15-in ==> pin15
4 bit OUT FALSE parport.0.pin-15-in-not
4 bit IN FALSE parport.0.pin-16-out <== pin16
4 bit IN FALSE parport.0.pin-17-out <== pin17
Pin Aliases:
Alias Original Name
Signals:
Type Value Name (linked to)
bit FALSE pin01
<== PortTest.btn01
==> PortTest.led-01
==> parport.0.pin-01-out
bit FALSE pin02
<== PortTest.btn02
==> PortTest.led-02
==> parport.0.pin-02-out
bit FALSE pin03
<== PortTest.btn03
==> PortTest.led-03
==> parport.0.pin-03-out
bit FALSE pin04
<== PortTest.btn04
==> PortTest.led-04
==> parport.0.pin-04-out
bit FALSE pin05
<== PortTest.btn05
==> PortTest.led-05
==> parport.0.pin-05-out
bit FALSE pin06
<== PortTest.btn06
==> PortTest.led-06
==> parport.0.pin-06-out
bit FALSE pin07
<== PortTest.btn07
==> PortTest.led-07
==> parport.0.pin-07-out
bit FALSE pin08
<== PortTest.btn08
==> PortTest.led-08
==> parport.0.pin-08-out
bit FALSE pin09
<== PortTest.btn09
==> PortTest.led-09
==> parport.0.pin-09-out
bit TRUE pin10
==> PortTest.led-10
<== parport.0.pin-10-in
bit TRUE pin11
==> PortTest.led-11
<== parport.0.pin-11-in
bit TRUE pin12
==> PortTest.led-12
<== parport.0.pin-12-in
bit TRUE pin13
==> PortTest.led-13
<== parport.0.pin-13-in
bit FALSE pin14
<== PortTest.btn14
==> PortTest.led-14
==> parport.0.pin-14-out
bit TRUE pin15
==> PortTest.led-15
<== parport.0.pin-15-in
bit FALSE pin16
<== PortTest.btn16
==> PortTest.led-16
==> parport.0.pin-16-out
bit FALSE pin17
<== PortTest.btn17
==> PortTest.led-17
==> parport.0.pin-17-out
Parameters:
4 u32 RW 0x00000000 parport.0.debug1
4 u32 RW 0x00000000 parport.0.debug2
4 bit RW FALSE parport.0.pin-01-out-invert
4 bit RW FALSE parport.0.pin-01-out-reset
4 bit RW FALSE parport.0.pin-02-out-invert
4 bit RW FALSE parport.0.pin-02-out-reset
4 bit RW FALSE parport.0.pin-03-out-invert
4 bit RW FALSE parport.0.pin-03-out-reset
4 bit RW FALSE parport.0.pin-04-out-invert
4 bit RW FALSE parport.0.pin-04-out-reset
4 bit RW FALSE parport.0.pin-05-out-invert
4 bit RW FALSE parport.0.pin-05-out-reset
4 bit RW FALSE parport.0.pin-06-out-invert
4 bit RW FALSE parport.0.pin-06-out-reset
4 bit RW FALSE parport.0.pin-07-out-invert
4 bit RW FALSE parport.0.pin-07-out-reset
4 bit RW FALSE parport.0.pin-08-out-invert
4 bit RW FALSE parport.0.pin-08-out-reset
4 bit RW FALSE parport.0.pin-09-out-invert
4 bit RW FALSE parport.0.pin-09-out-reset
4 bit RW FALSE parport.0.pin-14-out-invert
4 bit RW FALSE parport.0.pin-14-out-reset
4 bit RW FALSE parport.0.pin-16-out-invert
4 bit RW FALSE parport.0.pin-16-out-reset
4 bit RW FALSE parport.0.pin-17-out-invert
4 bit RW FALSE parport.0.pin-17-out-reset
4 s32 RO 3372 parport.0.read.time
4 s32 RW 16476 parport.0.read.tmax
4 u32 RW 0x00000000 parport.0.reset-time
4 s32 RO 0 parport.0.reset.time
4 s32 RW 0 parport.0.reset.tmax
4 s32 RO 6740 parport.0.write.time
4 s32 RW 21680 parport.0.write.tmax
4 s32 RO 0 parport.read-all.time
4 s32 RW 0 parport.read-all.tmax
4 s32 RO 0 parport.write-all.time
4 s32 RW 0 parport.write-all.tmax
Parameter Aliases:
Alias Original Name
Exported Functions:
Owner CodeAddr Arg FP Users Name
00004 fab9d000 fab560b8 NO 1 parport.0.read
00004 fab9d219 fab560b8 NO 0 parport.0.reset
00004 fab9d2fa fab560b8 NO 1 parport.0.write
00004 fab9d0ac fab560b8 NO 0 parport.read-all
00004 fab9d488 fab560b8 NO 0 parport.write-all
Realtime Threads:
Period FP Name ( Time, Max-Time )
999857 YES porttest ( 10112, 25184 )
1 parport.0.read
2 parport.0.write
halcmd:
halcmd: show
7 RT threads ready
Component Pins:
Pin Aliases:
Alias Original Name
Signals:
bit FALSE pin01
<== PortTest.btn01
==> PortTest.led-01
bit FALSE pin02
<== PortTest.btn02
==> PortTest.led-02
bit FALSE pin03
<== PortTest.btn03
==> PortTest.led-03
bit FALSE pin04
<== PortTest.btn04
==> PortTest.led-04
bit FALSE pin05
<== PortTest.btn05
==> PortTest.led-05
bit FALSE pin06
<== PortTest.btn06
==> PortTest.led-06
bit FALSE pin07
<== PortTest.btn07
==> PortTest.led-07
bit FALSE pin08
<== PortTest.btn08
==> PortTest.led-08
bit FALSE pin09
<== PortTest.btn09
==> PortTest.led-09
bit TRUE pin10
==> PortTest.led-10
bit TRUE pin11
==> PortTest.led-11
bit TRUE pin12
==> PortTest.led-12
bit TRUE pin13
==> PortTest.led-13
bit FALSE pin14
<== PortTest.btn14
==> PortTest.led-14
bit TRUE pin15
==> PortTest.led-15
bit FALSE pin16
<== PortTest.btn16
==> PortTest.led-16
bit FALSE pin17
<== PortTest.btn17
==> PortTest.led-17
Parameters:
Parameter Aliases:
Alias Original Name
Exported Functions:
Realtime Threads:
1 parport.0.read
2 parport.0.write
jeden LPT a dva seriove
spustam v terminali:
súbor:
ptest.hal
obsah:
loadrt hal_parport cfg="0xd400 out"
start
# loadusr halmeter
subor:
ptest.xml
obsah:
!-- Test panel for the parallel port cfg for out --><pyvcp><hbox><labelframe text="Outputs"><font>("Helvetica",16)</font><hbox><relief>RIDGE</relief><bd>2</bd><button><halpin>"btn01"</halpin><text>"Pin 01"</text></button><led><halpin>"led-01"</halpin><size>25</size><on_color>"green"</on_color><off_color>"red"</off_color></led><button><halpin>"btn02"</halpin><text>"Pin 02"</text></button><led><halpin>"led-02"</halpin><size>25</size><on_color>"green"</on_color><off_color>"red"</off_color></led></hbox><hbox><relief>RIDGE</relief><bd>2</bd><button><halpin>"btn03"</halpin><text>"Pin 03"</text></button><led><halpin>"led-03"</halpin><size>25</size><on_color>"green"</on_color><off_color>"red"</off_color></led><button><halpin>"btn04"</halpin><text>"Pin 04"</text></button><led><halpin>"led-04"</halpin><size>25</size><on_color>"green"</on_color><off_color>"red"</off_color></led></hbox><hbox><relief>RIDGE</relief><bd>2</bd><button><halpin>"btn05"</halpin><text>"Pin 05"</text></button><led><halpin>"led-05"</halpin><size>25</size><on_color>"green"</on_color><off_color>"red"</off_color></led><button><halpin>"btn06"</halpin><text>"Pin 06"</text></button><led><halpin>"led-06"</halpin><size>25</size><on_color>"green"</on_color><off_color>"red"</off_color></led></hbox><hbox><relief>RIDGE</relief><bd>2</bd><button><halpin>"btn07"</halpin><text>"Pin 07"</text></button><led><halpin>"led-07"</halpin><size>25</size><on_color>"green"</on_color><off_color>"red"</off_color></led><button><halpin>"btn08"</halpin><text>"Pin 08"</text></button><led><halpin>"led-08"</halpin><size>25</size><on_color>"green"</on_color><off_color>"red"</off_color></led></hbox><hbox><relief>RIDGE</relief><bd>2</bd><button><halpin>"btn09"</halpin><text>"Pin 09"</text></button><led><halpin>"led-09"</halpin><size>25</size><on_color>"green"</on_color><off_color>"red"</off_color></led><button><halpin>"btn14"</halpin><text>"Pin 14"</text></button><led><halpin>"led-14"</halpin><size>25</size><on_color>"green"</on_color><off_color>"red"</off_color></led></hbox><hbox><relief>RIDGE</relief><bd>2</bd><button><halpin>"btn16"</halpin><text>"Pin 16"</text></button><led><halpin>"led-16"</halpin><size>25</size><on_color>"green"</on_color><off_color>"red"</off_color></led><button><halpin>"btn17"</halpin><text>"Pin 17"</text></button><led><halpin>"led-17"</halpin><size>25</size><on_color>"green"</on_color><off_color>"red"</off_color></led></hbox></labelframe><labelframe text="Inputs"><font>("Helvetica",16)</font><hbox><relief>RIDGE</relief><bd>2</bd><label><text>"Pin 10"</text><font>("Helvetica",14)</font></label><led><halpin>"led-10"</halpin><size>25</size><on_color>"green"</on_color><off_color>"red"</off_color></led></hbox><hbox><relief>RIDGE</relief><bd>2</bd><label><text>"Pin 11"</text><font>("Helvetica",14)</font></label><led><halpin>"led-11"</halpin><size>25</size><on_color>"green"</on_color><off_color>"red"</off_color></led></hbox><hbox><relief>RIDGE</relief><bd>2</bd><label><text>"Pin 12"</text><font>("Helvetica",14)</font></label><led><halpin>"led-12"</halpin><size>25</size><on_color>"green"</on_color><off_color>"red"</off_color></led></hbox><hbox><relief>RIDGE</relief><bd>2</bd><label><text>"Pin 13"</text><font>("Helvetica",14)</font></label><led><halpin>"led-13"</halpin><size>25</size><on_color>"green"</on_color><off_color>"red"</off_color></led></hbox><hbox><relief>RIDGE</relief><bd>2</bd><label><text>"Pin 15"</text><font>("Helvetica",14)</font></label><led><halpin>"led-15"</halpin><size>25</size><on_color>"green"</on_color><off_color>"red"</off_color></led></hbox></labelframe></hbox></pyvcp>
súbor:
ptest.hal
obsah:
start
# loadusr halmeter
subor:
ptest.xml
obsah:
