Mesa 5i25 a 7i76
Hello Filip, I am so sorry I am sure we cannot process your order on line due to the country and tomorrow I will try again and let you know. If it works I can adjust your invoice without the $100. charge. If it does not work the $100. fee is for us to hand write the three documents and drive it to the Post Office then stand in line for 35 to 45 minutes, plus we do not know the what the total cost would be either and we do not have staff to do it for us. I am sorry for the inconvienene but you can certainly go to one of our dealers of your choice since they are closer. Try Toromatic and ask for Michal you may get a good price from him. Please let me know what you find out so we can cancel order new order and before you do that I will email you with the results when we try to ship it online tomorrow. Katharine
to robokop: Máš své obavy o latenci a propustnost nějak podložené? Přiznám, že jsem se nezabýval technickými detaily, ale parport se běžně používá na SW stepgeny a pracuje se s ním z pohledu PC přibližně stejně jako s PCI sběrnicí, tudíž latence vůči servosmyčce bych se neobával. V ECP módu má propustnost 2,5 MByte/s, což by na přenos hodnot stepgenů, enkodérů a případných dat pro expanzní IO mohlo stačit. A je pravda, že rozchodit něco přes parport bude řádově jednodušší (i na výrobu PCB) než kompletní karta do PCI/PCIe slotu.
řešením by mohlo byt shipito nebo jiná služba zajišťující "adresu" v USArobokop píše:Hello Filip, I am so sorry I am sure we cannot process your order on line due to the country and tomorrow I will try again and let you know. If it works I can adjust your invoice without the $100. charge. If it does not work the $100. fee is for us to hand write the three documents and drive it to the Post Office then stand in line for 35 to 45 minutes, plus we do not know the what the total cost would be either and we do not have staff to do it for us. I am sorry for the inconvienene but you can certainly go to one of our dealers of your choice since they are closer. Try Toromatic and ask for Michal you may get a good price from him. Please let me know what you find out so we can cancel order new order and before you do that I will email you with the results when we try to ship it online tomorrow. Katharine
yaqwsx
ten parport nemam nikterak podlozeny ani zmereny
proste vychazim z toho ze to je urcene pro jehlickove tiskarny a tam bych to nechal
vychazim z toho jake jsou problemy kdyz se to pouziva na sw generovani pulzu
z toho ze to je navrzene na jiny ucel a z toho ze delam profi stroje ne hobby
proto radsi volim reseni typu kanon na vrabce nez hobby bastleni
navic mi ta mesa dost vyhovovala prave modularnosti sserial a tudiz ruzne decentralizovane pomale IO
neco na desce se vzduchem a festo neco na ovladacim pultu neco v rozvadeci vse protahane kablikem podobnym ethernetu jen vyssim lanenim
ono uz jen tahle filozofie natolik zkrati nasazeni te elektroniky ze usetrim dejmetomu ke 30 000,- Kc za cesty a praci a to je sakra znat
tak jsem zacal komunikovat s firmou ze slovenska ktera zde inzeruje novy hardware
garantuji pro me vpohode pouzitelne kmitocty atd...
jestli v brzku nesezenu mesu pujdu do toho ale bude to pro me docela drahe to v pulce realizace zase cele predelavat
rozhodne do toho jdu na testovani a do dalsich masin
Pokud jsou to Blaváci z toho vlákna na které odkazuje o kousek výše trxtechnologies, tak dej nějaké info - ceny, termíny dodání atd., když už jim tady ve vlasním vlákně nestojíme za to, aby informovali a odpovídali na dotazy i když vím že to čtou ...
jojo jsou
ceny jeste neznaji protoze resi levnejsi vyrobu tistaku v cine a cele je to v testovani
az bude neco oficialniho napisou to sami nebo to sem hodim sam
ale oproti mese to vychazi levneji a bude to udajne jeste levnejsi prave kvuli te cinske vyrobe
jj maji jen raspberry ale je to uceleny system a maji nejake garantovane parametry smerem k pohonum a od odmerovani ktere mi v tuhle chvili vyhovuji a neni to pripojene k PC misto jehlickovky
- Kilovolt
Dotaz neznalého- o kolik míň spolehlivý je použití ethernet karty (např 7i80 a pod) místo lpt a pci ? Mě by se něco takovýho (s eth) docela hodilo.
robokop píše:neni to pripojene k PC misto jehlickovky
Ty teda nějak to LPT nemáš rád.
Přitom je uplně obyčejný paralelní port, dneska s novými režimy EPP a ECP i obousměrný a dokonce s podporou DMA.
Že se na to dá připojit i tiskárna je takový bonus navíc, ten kvality tohoto řešení nijak nesnižuje.
To bys rovnou mohl zatratit i celé PC, protože se na něm dají provozovat takové úchyloviny jako je třeba Fejsbůk.
... škoda jenom že to Raspbery Pi nestíhá i to grafcké rozhraní
Buďto na to už nemá dostatek výkonu, nebo (jak to je v Linuxu obvyklé) neexistuje vhodný ovladač, nebo se existující ovladač nemá rád s RealTime jádrem.
Další slabina je v tom že je to (alespoň zatím) uzavřený systém - zajíc v černém pytli (dobře maskovaný) s nějakou definovanou funkcionalitou jejíž modifikace není asi možná.
