mach 3 nesedi cad a cam
froxby
12. 6. 2016, 2:20
zdravim dnes jsem doladil masinu zkalibrovval osy a zacal kreslit
nakreslil jsem okotoval jsem a vyexportoval do dxf v sheetcam jsem udelal draahy a vyexportoval jsem post procesor ...gcode
po vloženi do machu a zacnul frezovat ... vysledek mi zdesil viz foto ... plan original
zde je jeste gcode co mi vydal sheetcam
Kód: Vybrat vše
N0010 (Filename: r9_fin.tap)
N0020 (Post processor: Mach3 2D.scpost)
N0030 (Date: 12/06/2016)
N0040 G21 (Units: Metric)
N0050 G40 G90 G91.1
N0060 F1
N0070 (Part: r9_fin)
N0080 (Operation: Outside Offset, 1lay, T1: Mill/router, 6 mm diameter, 3 mm Deep)
N0090 (Mill/router, 6 mm diameter)
N0100 T1 M06  G43 H1
N0110 M00 (Set Z to 32.0000)
N0120 G00
N0130 M03 S20000
N0140 X57.4471 Y11.7140
N0150 M00 (Set Z to 28.5000)
N0160 M00 (Set Z to 27.0000)
N0170 G01 F130
N0180 X58.8316 Y11.7248 F250
N0190 G03 X61.7931 Y15.0260 I-0.0234 J2.9999 F250.0
N0200 G01 X47.2025 Y159.5425 F250
N0210 G03 X44.1124 Y162.2393 I-2.9848 J-0.3014 F250.0
N0220 G01 X34.8070 Y161.9127 F250
N0230 G03 X31.9193 Y159.1199 I0.1052 J-2.9982 F250.0
N0240 G01 X22.0070 Y14.6666 F250
N0250 G03 X25.0234 Y11.4613 I2.9930 J-0.2054 F250.0
N0260 G01 X26.4583 Y11.4725 F250
N0270 X26.4830 Y9.9514
N0280 G03 X29.5059 Y7.0001 I2.9996 J0.0486 F250.0
N0290 G01 X54.4947 Y7.1948 F250
N0300 G03 X57.4709 Y10.2433 I-0.0234 J2.9999 F250.0
N0310 G01 X57.4471 Y11.7140 F250
N0320 M00 (Set Z to 26.0000)
N0330 F130
N0340 X58.8316 Y11.7248 F250
N0350 G03 X61.7931 Y15.0260 I-0.0234 J2.9999 F250.0
N0360 G01 X47.2025 Y159.5425 F250
N0370 G03 X44.1124 Y162.2393 I-2.9848 J-0.3014 F250.0
N0380 G01 X34.8070 Y161.9127 F250
N0390 G03 X31.9193 Y159.1199 I0.1052 J-2.9982 F250.0
N0400 G01 X22.0070 Y14.6666 F250
N0410 G03 X25.0234 Y11.4613 I2.9930 J-0.2054 F250.0
N0420 G01 X26.4583 Y11.4725 F250
N0430 X26.4830 Y9.9514
N0440 G03 X29.5059 Y7.0001 I2.9996 J0.0486 F250.0
N0450 G01 X54.4947 Y7.1948 F250
N0460 G03 X57.4709 Y10.2433 I-0.0234 J2.9999 F250.0
N0470 G01 X57.4471 Y11.7140 F250
N0480 M00 (Set Z to 32.0000)
N0490 G00
N0500 X10.0000 Y10.0000
N0510 M05
N0520 M05 M30
1. kde je proble mach nebo sheetcam nebo export dxf
2. je chyba v hw /modra deska tb6560
3 dekuji za jakekoli nametz kde je chyba
original vs plan
original vs plan
froxby
12. 6. 2016, 2:26
jeste dodavam rozmer
//plan > delka 149
obrobek> delka 135
12. 6. 2016, 2:32
ta frézka dělá špatně jen tento jediný výrobek a nebo i jiné? pokud i jiné dělá to celou dobu a nebo to někdy dřív šlo správně?
začni postupně: vynuluj souřadnice a nech frézku ujet třeba 100mm a změř.. pokud to bude OK, tak nakresli třeba čtverec 100x100 a vygeneruj Gkod a zase to vyrob a postupně musíš přijít na to kde je problém..
froxby
12. 6. 2016, 3:02
no je to 1.vzrobek co jsem na tom dělal takze zkusim rekalibraci a udelat nejaky ctverec 100 na 100
wolf
12. 6. 2016, 4:05
Podle G kódu, při průměru nástroje 6mm, by měl mít obrobek délku cca těch 149, takže DXF a SheetCAM vypadá, že dělá co má. Asi něco v MACH3(nastavení), nebo potom již asi jenom stroj...
wolf
froxby
12. 6. 2016, 4:09
tak je to asi kalibraci os ctverec v manualnim rizeni neodpovidal hodnotam
Zpět na „MACH všech verzí“
