Udělal jsem krávovinu a povolil upgrade (update? mám v tom hokej) a nenabíhá mi EMC2. Mám Wheezy - co je tam ted neumím zjistit, ale spadne to při staru EMC asi na AXISu. Když nakopnu stepconf, vše šlape, testy cvičí s osama jak mají, tak si myslím (?-bolí to
Může mi někdo poradit?
- Print file information:
RUN_IN_PLACE=no
LINUXCNC_DIR=
LINUXCNC_BIN_DIR=/usr/bin
LINUXCNC_TCL_DIR=/usr/lib/tcltk/linuxcnc
LINUXCNC_SCRIPT_DIR=
LINUXCNC_RTLIB_DIR=/usr/realtime-3.4-9-rtai-686-pae/modules/linuxcnc
LINUXCNC_CONFIG_DIR=
LINUXCNC_LANG_DIR=/usr/share/linuxcnc/tcl/msgs
INIVAR=inivar
HALCMD=halcmd
LINUXCNC_EMCSH=/usr/bin/wish8.5
LINUXCNC - 2.7.10
Machine configuration directory is '/home/peter/linuxcnc/configs/fiam-cnc_drevo'
Machine configuration file is 'fiam-cnc_drevo.ini'
INIFILE=/home/peter/linuxcnc/configs/fiam-cnc_drevo/fiam-cnc_drevo.ini
PARAMETER_FILE=linuxcnc.var
TASK=milltask
HALUI=
DISPLAY=axis
Starting LinuxCNC...
Starting LinuxCNC server program: linuxcncsvr
Loading Real Time OS, RTAPI, and HAL_LIB modules
Starting LinuxCNC IO program: io
Found file(REL): ./fiam-cnc_drevo.hal
Found file(REL): ./custom.hal
Starting TASK program: milltask
Starting DISPLAY program: axis
Shutting down and cleaning up LinuxCNC...
Killing task linuxcncsvr, PID=6425
Killing task milltask, PID=6478
task: 43 cycles, min=0.000006, max=0.010101, avg=0.006801, 0 latency excursions (> 10x expected cycle time of 0.010000s)
Removing HAL_LIB, RTAPI, and Real Time OS modules
Removing NML shared memory segments
