Ma pravdu. A taky na DDCS funguje open source firmware Pandora CNC, ktery pridava a vylepsuje nektere fce.
Masso
přesně tak....neni mě dobrej....otázka byla jestli má někdo zkušenost s Masso.....
A máš co dodat k tématu nebo si přišel rejt? na vás sem alergickej...běž si povídat do hospody
mal som v plane nieco k veci dodat, len som si chcel ujasnit situaciu.
samozrejme pokial si na mna alergicky, tak je zbytocne ti odovzdavat skusenosti
po tvojom poslednom prispevku ti mozem poradit akurat hladanie podla klucoveho slova ZYRTEC
a ze nekecam
Re: Anyone using a Masso CNC controller? Thoughts
As I stated in my write-up. IF you are just starting out into CNC and have never seriously used a mature CNC controller, The MASSO may work out ok for you. Otherwise it is seriously lacking and buggy.
One area that is major issue that I dont see them ever resolving is the Gcode load time. Its ok for simple parts, but I found that complex Gcode, takes it forever to load. I had one Gcode program that took it over 5 minutes to load.
If you have a PC, any kind of PC. Get UCCNC or Mach3, and a UC100 controller. They both run circles around the MASSO and are cheaper. That combination will work on any version of windows (even Windows and a Mac). Dont think you are not going to need a PC somewhere in your workflow. You will need one to process your drawing files and create your Gcode.
Im not saying the MASSO will never be a good choice, its just not ready now. They need to stop working on new features and get back to the core fix and tune some things. Once they do that, I will be more than willing to give them another try.
Author of: The CNC Construction Set Books, the KRMx01, KRMx02, KRmc01, and KRmf70 CNC Books, the HANS Electric gear clock book. All available at www.kronosrobotics.com.
super...stačilo to sem šoupnout hned....nejsem alergickej na tebe. Ale na to že mě říkáš že mě neni něco dobrý.......xener píše: ↑15. 9. 2020, 7:42 a ze nekecam
takže masso až na dlouhé načítání dobrý.....to Mach má teda horší průsery
no neviem ci ti to prekladal google alebo si pouzival nejaky iny slovnik, ale ja tam vidim ze je bugovy a obmedzeny , okrem problemu s nacitavanim g-kodu.
ale pokial sa citis, ako je tam pisane, zacinajucim pouzivatelom CNC bez vyssich narokov, tak je to celkom vyhovujuce zariadenie.
je viac ciest ako sa zbavit problemov s mach na windowse, ty si si vybral jednu z nich , neviem, mozno sa najde este jeden co by ta v tom podporil, ale zbytok ti povie jasne, ak sa chces niekam posunut, tak serva a linuxCNC, pripadne UCCNC , pripadne iny, zalozeny na opensource.
cokolvek ine podla mojho nazoru je zbytocna investicia, ktora ta o moc vyssie neposunie.
- GeminiRacing
caute, staviam novu masinu a uvazujem o 5 axis MASSO riadeni. Cinske kontrolery sa mi moc nepacia a maju integrovany maly displej. Na Masso viem pripojit velky VGA displej s Touch funkciou a je to standalone system, pocitacom mam vela ale uz ich nechcem vidiet. Ma to niekto z CZ/SK diy sceny a dalo by sa to vidiet ?
Masinka bude na 12Nm hybrid krokacoch, frame cca 400kg, 600x600x350, ATC vreteno, vymena nastrojov. Davam dotoho kopec eur tak nech aj riadiaci system za nieco stoji.
Pripadne ak mate nejake napady, cim to riadit....sem snimi
Vdaka, Miso
Vdaka, Miso
Renault 5 Turbo in progress
http://www.geminiracing.sk/" onclick="window.open(this.href);return false;
mám 5ti osé Masso...ale jestě nemám stroj hotový...dotyk funguje perfektně...a zatím jezdím jen se samotnýma closed loop 5nm a zatím žádný problém...bral sem i s blokem relátek a dotyk funkcí z holandska od dealera..dotyk obr mám zástavbovou přímo doporučovanou u které je jistota že fungujeGeminiRacing píše: ↑3. 11. 2020, 12:39 caute, staviam novu masinu a uvazujem o 5 axis MASSO riadeni. Cinske kontrolery sa mi moc nepacia a maju integrovany maly displej. Na Masso viem pripojit velky VGA displej s Touch funkciou a je to standalone system, pocitacom mam vela ale uz ich nechcem vidiet. Ma to niekto z CZ/SK diy sceny a dalo by sa to vidiet ?
Vdaka, Miso
Je mozne ze to bude mit stejny problem s vykreslovanim jako ruzne varianty linuxcnc na raspberry. Chtelo by to zkusit natahnout pulgigovej g-kod zda to bude makat.
zatím sem do toho rval vše co sem našel a chodí to....ale klidně mě sem hod pulgigovej a zkusím ho....
