Tak trochu posun - díky Packo!!!
I za ten link!!!
Tohle je skvence, která nasaví teploty a počká:
M82 ;absolute extrusion mode
G21
G90
M82
M107 T0
M140 S40
M104 S200 T0
M190 S40
M109 S200 T0
Když jí dám před slicovaný model do gcode tak se tisk rozjede.
Upravil jsem podle toho i startovací sekvenci pro tuhle tiskárnu:
; X5SA Start Code
G21 ; Set units to millimeters
G90 ; Set all axis to Absolute
M82
; Uncomment the line below to enable ABL Mesh probing
;G29 ; Probe bed mesh for ABL
; For best results do not run nozzle heater while performing ABL
M107 T0; Disable all fans
M140 S{material_bed_temperature_layer_0} ; Set bed temperature
M104 S{material_print_temperature_layer_0} T0 ; Set nozzle temp
M190 S{material_bed_temperature_layer_0} ; Set bed temperature and wait
M109 S{material_print_temperature_layer_0} T0 ; Set nozzle temp and wait
G28 ; Home all axis
G1 Z15.0 F6000; Raise nozzle to prevent scratching of heat bed
G1 X0 Y0 ; Move nozzle to Home before heating
G0 E3 F200
G92 E0 ; Set Extruder position to zero
; Uncomment the following lines to enable nozzle purge line along left edge of bed
;G1 Z2.0 F3000 ; Raise Z axis
;G1 X1.1 Y20 Z0.2 F3600.0 ; Move to purge line start position
;G1 Y220 F1500.0 E10 ; Draw first purge line
;G1 X1.4 F3600.0 ; Move to side
;G1 Y20 F1500.0 E20 ; Draw second purge line
;G92 E0 ; Reset Extruder
;G1 Z2.0 F3000 ; Move Z Axis up little to prevent scratching of Heat Bed
;G1 X5 Y20 Z0.2 F3600.0 ; Move over to finish nozzle wipe
;G92 E0
Vygenerovaný gcode:
;FLAVOR:Marlin
;TIME:1646
;Filament used: 1.37576m
;Layer height: 0.15
;MINX:144
;MINY:144
;MINZ:0.2
;MAXX:186
;MAXY:186
;MAXZ:19.96
;Generated with Cura_SteamEngine 5.3.0
; X5SA Start Code
M82
M140 S40 ; Set bed temperature
M104 S200 T0 ; Set nozzle temp
M190 S40 ; Set bed temperature and wait
M109 S200 T0 ; Set nozzle temp and wait
G28 ; Home all axis
G0 E3 F200
Jak vidíte sekvence tam je A NIC
