EMC ani nenastartuje
Napsal: 1. 12. 2013, 12:18
Dobry vecer pani
mam problem, nainstaloval som ebuntu aj EMC na starsi PC po nainstalovani to slapalo avsak zjavne mala problem grafika, tak po stastiplnom boji sa nejak podarilo rozbehat grafiku(Radeon x1300) no zas nejde nastartovat EMC skonci to tmto logom, mate nejake napady co to moze byt ? Dakujem
Kód: Vybrat vše
Print file information:
RUN_IN_PLACE=no
LINUXCNC_DIR=
LINUXCNC_BIN_DIR=/usr/bin
LINUXCNC_TCL_DIR=/usr/lib/tcltk/linuxcnc
LINUXCNC_SCRIPT_DIR=
LINUXCNC_RTLIB_DIR=/usr/realtime-2.6.32-122-rtai/modules/linuxcnc
LINUXCNC_CONFIG_DIR=
LINUXCNC_LANG_DIR=/usr/share/linuxcnc/tcl/msgs
INIVAR=inivar
HALCMD=halcmd
LINUXCNC_EMCSH=/usr/bin/wish8.5
LINUXCNC - 2.5.3
Machine configuration directory is '/home/jakub/linuxcnc/configs/my-millcc'
Machine configuration file is 'my-millcc.ini'
INIFILE=/home/jakub/linuxcnc/configs/my-millcc/my-millcc.ini
PARAMETER_FILE=linuxcnc.var
TASK=milltask
HALUI=
DISPLAY=axis
Starting LinuxCNC...
Starting LinuxCNC server program: linuxcncsvr
Loading Real Time OS, RTAPI, and HAL_LIB modules
Starting LinuxCNC IO program: io
Starting TASK program: milltask
Starting DISPLAY program: axis
Shutting down and cleaning up LinuxCNC...
Killing task linuxcncsvr, PID=1626
Killing task milltask, PID=1675
Removing HAL_LIB, RTAPI, and Real Time OS modules
Removing NML shared memory segments
Cleanup done
Debug file information:
Can not find -sec MOT -var MOT -num 1
Can not find -sec IO -var IO -num 1
Can not find -sec LINUXCNC -var NML_FILE -num 1
Can not find -sec EMC -var NML_FILE -num 1
/usr/bin/linuxcnc: line 692: 1676 Segmentation fault $EMCDISPLAY -ini "$INIFILE" $EMCDISPLAYARGS $EXTRA_ARGS
1626
PID TTY STAT TIME COMMAND
1675
Stopping realtime threads
Unloading hal components
Kernel message information:
[ 203.159944] I-pipe: Domain RTAI registered.
[ 203.159955] RTAI[hal]: <3.8.1> mounted over IPIPE-NOTHREADS 2.6-03.
[ 203.159958] RTAI[hal]: compiled with gcc version 4.4.3 (Ubuntu 4.4.3-4ubuntu5) .
[ 203.159964] RTAI[hal]: mounted (IPIPE-NOTHREADS, IMMEDIATE (INTERNAL IRQs DISPATCHED), ISOL_CPUS_MASK: 0).
[ 203.159967] PIPELINE layers:
[ 203.159970] e1005e20 9ac15d93 RTAI 200
[ 203.159972] c085cb20 0 Linux 100
[ 203.182916] RTAI[malloc]: global heap size = 2097152 bytes, <BSD>.
[ 203.183073] RTAI[sched]: IMMEDIATE, MP, USER/KERNEL SPACE: <with RTAI OWN KTASKs>, kstacks pool size = 524288 bytes.
[ 203.183078] RTAI[sched]: hard timer type/freq = APIC/12515877(Hz); default timing: periodic; linear timed lists.
[ 203.183082] RTAI[sched]: Linux timer freq = 250 (Hz), TimeBase freq = 2002687000 hz.
[ 203.183084] RTAI[sched]: timer setup = 999 ns, resched latency = 2944 ns.
[ 203.183197] RTAI[usi]: enabled.
[ 203.258145] RTAI[math]: loaded.
[ 203.331949] config string '0x378 out '
[ 204.117367] axis[1676]: segfault at 4 ip 00a97ef6 sp bfdcc1c0 error 4 in libGL.so.1.2[a32000+a7000]
[ 204.709075] RTAI[math]: unloaded.
[ 204.760068] SCHED releases registered named ALIEN RTGLBH
[ 204.776816] RTAI[malloc]: unloaded.
[ 204.876035] RTAI[sched]: unloaded (forced hard/soft/hard transitions: traps 0, syscalls 0).
[ 204.879379] I-pipe: Domain RTAI unregistered.
[ 204.879389] RTAI[hal]: unmounted.
