mach 3 nesedi cad a cam
Napsal: 12. 6. 2016, 2:20
zdravim dnes jsem doladil masinu zkalibrovval osy a zacal kreslit
nakreslil jsem okotoval jsem a vyexportoval do dxf v sheetcam jsem udelal draahy a vyexportoval jsem post procesor ...gcode
po vloženi do machu a zacnul frezovat ... vysledek mi zdesil viz foto ... plan original
zde je jeste gcode co mi vydal sheetcam
1. kde je proble mach nebo sheetcam nebo export dxf
2. je chyba v hw /modra deska tb6560
3 dekuji za jakekoli nametz kde je chyba
Kód: Vybrat vše
N0010 (Filename: r9_fin.tap)
N0020 (Post processor: Mach3 2D.scpost)
N0030 (Date: 12/06/2016)
N0040 G21 (Units: Metric)
N0050 G40 G90 G91.1
N0060 F1
N0070 (Part: r9_fin)
N0080 (Operation: Outside Offset, 1lay, T1: Mill/router, 6 mm diameter, 3 mm Deep)
N0090 (Mill/router, 6 mm diameter)
N0100 T1 M06 G43 H1
N0110 M00 (Set Z to 32.0000)
N0120 G00
N0130 M03 S20000
N0140 X57.4471 Y11.7140
N0150 M00 (Set Z to 28.5000)
N0160 M00 (Set Z to 27.0000)
N0170 G01 F130
N0180 X58.8316 Y11.7248 F250
N0190 G03 X61.7931 Y15.0260 I-0.0234 J2.9999 F250.0
N0200 G01 X47.2025 Y159.5425 F250
N0210 G03 X44.1124 Y162.2393 I-2.9848 J-0.3014 F250.0
N0220 G01 X34.8070 Y161.9127 F250
N0230 G03 X31.9193 Y159.1199 I0.1052 J-2.9982 F250.0
N0240 G01 X22.0070 Y14.6666 F250
N0250 G03 X25.0234 Y11.4613 I2.9930 J-0.2054 F250.0
N0260 G01 X26.4583 Y11.4725 F250
N0270 X26.4830 Y9.9514
N0280 G03 X29.5059 Y7.0001 I2.9996 J0.0486 F250.0
N0290 G01 X54.4947 Y7.1948 F250
N0300 G03 X57.4709 Y10.2433 I-0.0234 J2.9999 F250.0
N0310 G01 X57.4471 Y11.7140 F250
N0320 M00 (Set Z to 26.0000)
N0330 F130
N0340 X58.8316 Y11.7248 F250
N0350 G03 X61.7931 Y15.0260 I-0.0234 J2.9999 F250.0
N0360 G01 X47.2025 Y159.5425 F250
N0370 G03 X44.1124 Y162.2393 I-2.9848 J-0.3014 F250.0
N0380 G01 X34.8070 Y161.9127 F250
N0390 G03 X31.9193 Y159.1199 I0.1052 J-2.9982 F250.0
N0400 G01 X22.0070 Y14.6666 F250
N0410 G03 X25.0234 Y11.4613 I2.9930 J-0.2054 F250.0
N0420 G01 X26.4583 Y11.4725 F250
N0430 X26.4830 Y9.9514
N0440 G03 X29.5059 Y7.0001 I2.9996 J0.0486 F250.0
N0450 G01 X54.4947 Y7.1948 F250
N0460 G03 X57.4709 Y10.2433 I-0.0234 J2.9999 F250.0
N0470 G01 X57.4471 Y11.7140 F250
N0480 M00 (Set Z to 32.0000)
N0490 G00
N0500 X10.0000 Y10.0000
N0510 M05
N0520 M05 M30
