Fanuc frazovanie zavitu problem
Napsal: 20. 12. 2017, 12:19
Prosim o radu, chcem frezovat zavit na Fanucu, v postprocesore mam nastaveny cyklus na G84, programujem to v Catii cez operaciu Tapping a vyhadzuje mi pri tom alarm 204 - ILLEGAL AXIS OPERATION, viete mi niekto poradit co treba nastavit aby to islo? o tom alarme som nasiel toto: "In the rigid tap, an axis movement is specified between the rigid M code (M29) block and G84 or G74 for M series (G84 or G88 for T series) block. Modify the program."
Pripajam zapis programu:
O246
N10 (MIN X-15. Y0. Z22.)
N11 (MAX X-15. Y0. Z42.)
N12 (NASTROJ=ZAVITNIK M8)
N13 (PRUMER= 8.000000)
N14 (ZAOBLENI=)
N15 T11 M6
N16 S300 M29
N17 M8
N18 (TAPPING.1)
N19 G0 G90 G56 X-15. Y0.
N20 G0 G43 H11 Z42.
N21 G1 Z32. F350.
N22 G84 G99 Z-7. R32. F375.
N23 G80
N24 G1 Z42. F1000.
N25 M5
N26 M9
N27 M30
Alarm vyhodi pri riadku N19. Dakujem vopred za rady
O246
N14 (ZAOBLENI=)
N15 T11 M6
N16 S300 M29
N17 M8
N18 (TAPPING.1)
N20 G0 G43 H11 Z42.
N21 G1 Z32. F350.
N23 G80
N24 G1 Z42. F1000.
N25 M5
N26 M9
N27 M30
