nastavení délky nástroje
Napsal: 30. 1. 2021, 5:25
od petan1986
Zdravim,
pouřeboval bych poradit ohledně nastavneí délky nástroje v machu3, moc to nechápu jak to má fungovat. tlačítko SET TOOL HEIGHT
používám tohle prostředí:
http://www.physanon.com/pa-mach-3-screen-set/
probe:
https://www.aliexpress.com/item/3301520 ... web201603_
skript:
Kód: Vybrat vše
Sub Main()
' Z- Probing Script
' Author verser
' vers.by - touch probes, tool setters and precision home switches
Dim FRate1, FRate2
Dim DMax, Latch, EdgeLength
Dim XYclearance
Dim AutoZeroFlag
Dim ToolNo
Dim ToolD
Dim ProbeD
Dim Zdepth
Dim ZHit
Dim Zpos
Dim ZScale
Dim AbsIncFlag
Dim CurrentFeed
'Init vars
FRate1 = Abs(GetUserDRO(1821))
FRate2 = Abs(GetUserDRO(1822))
DMax = Abs(GetUserDRO(1823))
ToolNo = GetCurrentTool()
ToolD = GetToolParam(ToolNo,1)
   If GetUserDRO(1829) = 0 Then
   	ProbeD = ToolD
	Else
	ProbeD = GetUserDRO(1829)
   End If
Latch = abs(GetUserDRO(1825))
Zdepth = GetUserDRO(1830)
If GetOEMLED(1871) Then
AutoZeroFlag=1
Else
AutoZeroFlag=0
End If
AbsIncFlag = GetOEMLED(49)   ' Get the current G91 state
'Temporary save all Axis Scale factors
ZScale = GetOEMDRO(61)
'Set Z Scale to 1
SetOEMDRO(61,1)
Sleep(250)
'Check for Errors
If GetOemLED(16)<>0 Then ' Check for Machine Coordinates
Message "Please change to working coordinates"
SetOEMDRO(61,ZScale)
Sleep(250)
Exit Sub ' Exit if in Machine Coordinates
End If
If GetOemLED(825)<>0 Then
Message "Probe is active! Check connection and try again"
Call SetOEMDRO(61,ZScale)
Sleep(250)
Exit Sub ' Exit if probe is tripped
End If
CurrentFeed = GetOEMDRO(818) 'FeedRate()
'main working
	'Save Z start position
	Zpos = GetDRO(2)
	'Probe Z-
	ZHit=ProbeZ(-1,DMax,Latch,FRate1,FRate2)
	If ZHit=999999 Then
		Exit Sub
	End If
	SetUserLabel (14, Format(ZHit, "####0.000"))
	PushMSG("Z- = " & (ZHit))
	'Safe back to start position
	If Not SafeMoveZ((Zpos-GetDRO(2)),FRate1) Then
		PushMSG("Return to the search position is interrupted")
		Exit Sub
	End If
	If AutoZeroFlag = 1 Then
		SetOEMDRO(42, ZHit)
		Sleep(150)
	End If
'epilog
Sleep(250)
Call SetLED49(AbsIncFlag)
SetOEMDRO(818,CurrentFeed) 'SetFeedRate(CurrentFeed)
Sleep(125)
End Sub
'Functions
Function ProbeZ(Dir,DMax,Latch,FRate1,FRate2)
	Dim Res
    Dim Zstart
	Dim Ftmp
	Dim AbsIncF
	ProbeZ=999999
	Zstart = GetDRO(2)
	Ftmp = FeedRate() 'FeedRate()
	AbsIncF=GetOEMLED(49)
	'Fast Probe Z
	Code "G91"
	Code "F" & FRate1
	Sleep(125)
	Call WaitProbeReady()
	Code "G31 Z" & (Dir*DMax)
	While IsMoving()
	Wend
	Res = GetVar(2002)
'	PushMSG("Res=" & Res &", Zstart=" & Zstart & ", DMax=" & DMax & ", FRate1=" & FRate1)
	If Abs(Res - Zstart - Dir*DMax) < 0.01 Then
		PushMSG("Error: G31 Z search finished without making contact")
		PushMSG("Manually return to the starting position and repeat the search")
		Call SetLED49(AbsIncF)
		SetOEMDRO(818,Ftmp)
		Sleep(125)
		Exit Function
	End If
	'Move back
	Code "G00 Z" & -Dir*Latch
	While IsMoving()
	Wend
	'Latch Probe Z
	Zstart = GetDRO(2)
	Code "F" & FRate2
	Sleep(125)
	Code "G31 Z" & Dir*Latch*2
	While IsMoving()
	Wend
	'Save result
	Res = GetVar(2002)
	If Abs(Res - Zstart - Dir*Latch*2) < 0.01 Then
		PushMSG("Error: G31 Z latch finished without making contact")
		SetOEMDRO(818,Ftmp)
		Sleep(125)
		Exit Function
	End If
	While IsMoving()
	Wend
	SetOEMDRO(818,Ftmp)
	Sleep(125)
	ProbeZ=Res
End Function
Function SafeMoveZ(Z1, F1) As Boolean 'return 1 (error) if probe tripped
    Dim Zstart
	Dim Ftmp
	Dim AbsIncF
	SafeMoveZ=True
	Zstart = GetDRO(2)
	Code "G91"
	Code "F" & F1
	Sleep(125)
	Code "G31 Z" & Z1
	While IsMoving()
		Sleep(100)
	Wend
	ZHit = GetVar(2002)
	SetOEMDRO(23,Ftmp)
	Sleep(125)
End Function
Function PushMSG(Str1 As String) As Boolean
	SetUserLabel (21,GetUserLabel(20))
	SetUserLabel (20,GetUserLabel(19))
	SetUserLabel (19,GetUserLabel(18))
	SetUserLabel (18,GetUserLabel(17))
	SetUserLabel (17,Str1)
	Message Str1
	PushMSG=True
End Function
Sub WaitProbeReady()
	While GetOemLED(825)
		Sleep(100)
	Wend
End Sub
Sub SetLED49(Flag)
	If Flag Then
		Code "G91"
		Sleep(125)
	Else
		Code "G90"
		Sleep(125)
	End If
End Sub
