The Debian 10 Buster ISO will install a full Debian system with the required realtime kernel and the linuxcnc-uspace application. It uses a PREEMPT-RT patched kernel which is close to mainstream Linux but does not, in some cases, give quite such good realtime performance as the previous RTAI kernel. It is very often more than good enough. It should probably be the first version tried even if using a parallel port. This is compatible with all Mesa and Pico interface boards.
LinuxCNC 2.8.4 Debian 10 Buster RTAI
The more adventurous can install the Buster ISO and then install the experimental RTAI kernel as described in 2.8 documents The kernel-mode RTAI installation can not be used with Mesa Ethernet-interfaced cards.
Alebo nejaky Linuxcnc2.9?
Podla toho co citam by som mal pouzit: LinuxCNC 2.8.4 Debian 10 Buster RTAI ale isty som si neni
