motory 57BYGH41-401B
clifo2
Příspěvek 3. 10. 2012, 11:42
Dostal som darom motory 57BYGH41-401B, dajú sa použiť vôbec na niečo ?
Chcel by som vyskúšať svoju prvotinu - takú malú CNC gravírku.
K tomu by som ešte dokúpil drivery CNC Router One Axis TB6560 3.5A Two Phase Hybrid Stepper Motor Driver Controller http://www.goodluckbuy.com/cnc-router-o ... oller.html" onclick="window.open(this.href);return false;
a 5 Axis CNC Breakout Board Interface Adapter For PC Stepper Motor Driver http://www.goodluckbuy.com/5-axis-cnc-b ... cable.html" onclick="window.open(this.href);return false;
Bude to spolu chodiť a čo môžem od toho čakať?
Predom ďakujem.
Ešte pridávam technické údaje o motore:
Parameters:
- Step Angle Accuracy: ±5%(full step, no load)
- Resistance Accuracy: ±10%
- Inductance Accuracy: ±20%
- Temperature Rise: 80℃CMax.(ratod current,2 phase on)
- Ambient Temperature: -10℃-+50℃
- Insulation Class: B
- Dielectric Strength: 500V AC for one minute
- Shaft Radial Play: 0.06Max.(450g-load)
- Shaft Axial Play: 0.08Max.(450 9-load)
Specifications:
Model # : 57BYGH41-401
Resolution/Step Angle : 1.8°
Phases : 2
RPM : 3000
Voltage : 3.64VDC
Amperage : 1.5A
Leads (Wires) : 4 Leads
Phase Current : 0.4A
Winding Resistance : 2.7 Ohm
Inductance : 5.6 mH
Holding Torque : 69 oz/in. | 5.0 kgf/cm
Zpět na „Krokové motory“
