Stránka 2 z 3
Re: num 1060 software
Napsal: 11. 12. 2019, 8:17
od Juro
Toto v pocitaci mas spravne nastavene?
Napsal: 11. 12. 2019, 4:53
od hanz100
jo mam koukal sem na to nastaveni a menil podle navodu co je pdf vubec nic me to nedela
Napsal: 11. 12. 2019, 4:55
od Dawe
Ja vim zes to urcite kontroloval, ale nejcasteji za to muze kabel. Tady musi byt plne obsazeny, propiskej pin po pinu multimetrem.
Napsal: 11. 12. 2019, 4:59
od hanz100
13.1.2 Configuring the Port for the NUMCOM Software
NUMCOM is a public domain programme relatively widespread among NUM CNC users. It runs under DOS. It is used
to upload and download files via a serial interface. Other applications, such as NUMPC, are available from the NUM
network.
In order for NUMCOM to operate correctly, set the port as follows:
Line Number Free choice; see Sec. 13.1.
Standard RS232
Input Speed (Bds) 9600
Output Speed (Bds) 9600
Number of start bits 1
Number of data bits 8
Number of stop bits 1
Parity None
Protocol None
Flow Control RTS/CTS
Logical Name Free choice, but COMM1 is recommended
Configuration x/12 Accept
13.1.3 Selecting an Existing Configuration
Napsal: 11. 12. 2019, 5:00
od hanz100
kabel sem sam delal nemel sem krizovej tak sem ho daval dohromady podle tohodle
Napsal: 11. 12. 2019, 5:02
od hanz100
kabel
Napsal: 11. 12. 2019, 5:05
od Dawe
A mas to fakt dobre? Zkontroluj si to pin po pinu. RTS/CTS je taky krizene a protoze je na nich zavisly timing te seriove komunikace, tak to bez nich nepojede.
od hanz100
uz si nejak nevim rady nechtel sem to nejak degradovat tovarni kvalitu masiny ale asi do ni koupim kartu mesa a predelam to s boží pomoci :roll:
Napsal: 11. 12. 2019, 5:07
od hanz100
jdu se jeste na to mrknout
Napsal: 11. 12. 2019, 5:10
od hanz100
krizil sem pin 2 s3 a pin 7 s 8 pin 5 zustal na stejnu
Napsal: 11. 12. 2019, 5:21
od Dawe
A popropojovane piny 1,4,6,9 na PC strane mas?
Jestli pouzivas USB na RS-232 konvertor, tak zkus jiny, nebo lepe starsi PC primo s hw portem.
Jestli pouzivas 9pin->25pin redukci, tak ji propiskej, nebyvaji casto zapojene komplet.
Napsal: 11. 12. 2019, 5:29
od filla
jestli se ten sw pokousis spoustet na win7 a vyssi, tak to fungovat opravdu nebude, bude to chtit idealne w95/98, mozna to jeste pujde na xp
Napsal: 11. 12. 2019, 5:36
od Mex
filla píše: ↑11. 12. 2019, 5:29 jestli se ten sw pokousis spoustet na win7 a vyssi, tak to fungovat opravdu nebude, bude to chtit idealne w95/98, mozna to jeste pujde na xp
To víš nebo si to myslíš?
Obsluha sériových portů se většinu dělá (a dělala i dávno) pomocí služeb BIOSu a OS, nikoli přímým přístupem do registrů. Takže i starý DOSový program na COM by mohl fungovat.
Ten, co je v tom vlákně na CNCzone, je dokonce Windowsový, i když taky hodně historický.
Ale když tazatel není ani schopen/ochoten napsat co mu to dělá a co mu tedy vlastně nejede, tak to je pak těžké.
No ale každý svého štěstí strojvedoucím.
Napsal: 11. 12. 2019, 5:40
od filla
nekolikrat jsem se s tim setkal a navic to nefunguje s levnymi usb>serial, pokud potrebujes vic jak rx/tx/gnd
Napsal: 11. 12. 2019, 8:47
od Charon
filla píše: ↑11. 12. 2019, 5:40 nekolikrat jsem se s tim setkal a navic to nefunguje s levnymi usb>serial, pokud potrebujes vic jak rx/tx/gnd
Svatá pravda, proto skovávám starou IBM s com1 a win98 přesně na takovéhle špeky.
Jestli chceš půjčit, můžu ale jen osobně tam i zpět.
